RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Hyper 8.5 (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7582334-hyper-8-5-a.html)
Swingnamiss 06-05-2008 02:21 AM
Hyper 8.5
I have searched old threads and I am still confused. First of all I am new to this so I have an idea about things but dont fully understand some things. I am about to order a Hyper 8.5 Pro kit with a Hyper .21 8 port race engine with rear exhaust, Futaba 3PM Trans/Rec, Hitec HSC-5998 Titanium Gear Ultra Torque Servo S. What throttle servo would I need for this set up and if I am missing anything what else do I need to have it running once put together. I am not racing but will in the future thats why I went with the pro kit.
tommygun32 06-05-2008 02:55 AM
RE: Hyper 8.5
Welcome to the addiction Swingnamiss...:D
I have the Hyper 8.5 pro kit as well and the same transmitter/receiver mate. I LOVE IT:D. When it comes to the throttle servo, IMO it doesn't really need a lot of torque strength there. I use a 12.0 kg torque strength servo and find that's more than enough. What does matter is servo speed. You want a servo that will go through it's full motion as quickly as possible. I use the JR DS8715. it's full motion response time is 0.09 seconds/60 degrees. I'm sure there are quicker and better ones out there, but it depends on what you can find at your LHS. If you're not racing, your engine and pipe are more than enough. Later when it comes time to upgrade, all you'll need to do is get a race engine and exhaust and practice, practice, practice....
I personally recommend the OS Speed 21VZ-B V-SPEC AL with either an OS 2060 SC pipe or JR3 pipe[>:]. Again, it depends on what your LHS carries. Convenience goes a long way in this endeavour.
Tires are chosen for track conditions as are shock springs, shock oils and DIFF oils.
Oh and remember....practice, practice, practice. 80% of winning is driving....[&:]. You could have the absolutely best set up costing upwards of 5K, but it doesn't count for much if your car is always upside down, eh?
joydude630 06-05-2008 04:17 AM
RE: Hyper 8.5
Hey Tommygun32,
By the way where did you get the JR DS8715 from and how much?
Osirisf16 06-05-2008 04:35 AM
RE: Hyper 8.5
ORIGINAL: Swingnamiss
If you are going to race, then i recommend you waiting untill all the nines come out (hyper 9, inferno MP9, losi nine, etc). For throttle/braking you wanna something fast, so since you will buy a hitec servo, then go and get the 5965, it has .10 speed at 6 volts and somewhere 131 oz/inc torque. As a beginner is a very good starting kit, don't listen the others of buying a cheap buggy and you then see. If you will buy and stay to that, then buy something GOOD, not CRAP. ;) Better buying a crap engine with a good kit and then just replace the engine, just like you will do :D The KIT is ok you chosen, i can't thing something better at that price, go for it
tommygun32 06-05-2008 04:55 AM
RE: Hyper 8.5
Hey Joy, got it from the LHS behind Sana Fashions in Karama. 475/- but they'll give a discount.
You at the track tomorrow for the race???
Swingnamiss 06-05-2008 05:07 AM
RE: Hyper 8.5
I still feel unsure of the whole thing I guess what I'm really trying to find out is lets say I scrap the servo I mentioned, what would be a good servo combination for this truck (you do need 2 servos.... correct?)
Osirisf16 06-05-2008 05:09 AM
RE: Hyper 8.5
Right :D You need a servo on steering more than 200 oz/inc, and as for the throttle/braking one, its speed must be at least .13, so better buying one that has .10 speed. The servo on throttle/braking must have at least 130 oz/inc torque by the way. Now for the speed of the steering servo, a .14 is good enough i think. Too fast servos in steering can make your buggy flip somehow.
Swingnamiss 06-05-2008 05:16 AM
RE: Hyper 8.5
Ok so would that make the servos different for each or can you use the same servos for each but doesn't make sense because you dont need the same amount torque on the throttle/brake servo.
Osirisf16 06-05-2008 05:21 AM
RE: Hyper 8.5
Sorry but you confused me with that you said :D I'm just saying that you need a lot of torque at steering, and a good speed at throttle/braking so you have good throttle responses. The speed of the steering mustn't very great because you may have oversteer or something problems, and the torque in throttle/braking mustn't be very great too because it's overkilling. If your brakes are good, then a 5625 hitec servo is good (like mine, but i recommend more torque because i have it too, but anyway, the brakes varies, it depends on your braking system)
tommygun32 06-05-2008 05:44 AM
RE: Hyper 8.5
Hey Swingnamiss...
Ya buddy, you need two servos. Keep them the same brand, but different models. There are different kinds at different price ranges, ones with plastic gears, ones with metal/titanium gears and digital ones. Use two different kinds, same make, but different torques and response speeds. Talk to the store you're buying it from and ask them for their opinion. It depends on what's available in your local market as well. JR9000 range is considered amongst some of the best, Futaba digitals also up there. Hi-techs are good as well. Everyone has an opinion and personal choice about almost everything related to this sport mate. Also, keep in mind that some servo arms don't fit all servos. So make sure you get servo arms made for the servos you're running. And make sure the screw that goes through the servo arms fits the hole...
Your LHS (local hobby store) should be more than happy to point you in the right direction and explain all the reasons for the different requirements for the servos on you car. Satisfied customers tend to return with more business.
And as far as your choice in car...you'll love it;)
Swingnamiss 06-05-2008 05:47 AM
RE: Hyper 8.5
the whole servo thing got me confused because I don't know how to order the 2 servos by what I need or when I look to order them how are they catergorized.
Osirisf16 06-05-2008 05:50 AM
RE: Hyper 8.5
You can see which is analog and which is digital. Digital are stronger than analog. Digital servos are better. A few guys saying that analog is better because if something happen to servo, the analog are cheap enough to replace it, but i ran 5 years digital and no problem occured. The requirements that the servo must have are those i told you. Is nothing to confuse by ;)
tommygun32 06-05-2008 06:04 AM
RE: Hyper 8.5
Here you go Swingnamiss...
http://www.amainhobbies.com/index.php/cPath/1_61_100
There's also an 800 number on the top of the page, they're very friendly and helpful. Just tell them your situation, and they should be able to guide you to the right product.
Good luck
joydude630 06-05-2008 06:12 AM
RE: Hyper 8.5
Swingnamiss - Go for the ACE servos if its in your budget. They are expensive but worth it.
Tommygun32 - I sent you a pm.
Swingnamiss 06-05-2008 06:17 AM
RE: Hyper 8.5
Hey thanks guys I'm going to call the number you gave me.
cobra26 06-05-2008 07:14 AM
RE: Hyper 8.5
Is there any information or pictures out on the Hyper 9 that I can put my eyes on yet? I've searched but come up with nothing. Anyone know when they are supposed to be available?
vti-chris 06-05-2008 07:22 AM
RE: Hyper 8.5
[link=http://www.solott.com/foros/index.php?topic=108]Hyper 9 Pictures[/link]
cobra26 06-05-2008 09:21 AM
RE: Hyper 8.5
ORIGINAL: vti-chris
Thanks! Looks beefy and well thought out! Now, I guess I have to get in line with the question of when it will be available. I was hoping to run a new buggie this summer but it looks like I'll have to wait a while (August?). From what I see so far, I want one!
f575gtc 06-05-2008 09:37 AM
RE: Hyper 8.5
If you dont have a buggy now and want one don't wait for the hyper 9. the 9 won't be out till august hopefully, and you will want it out on the market for sometime before you buy one, look at the rc8 for an example, when it first came out it had durability issues and fuel tank issues, AE has fixed that since.
I bought a hyper 8.5 pro yesterday, all new from a hobby shop in a great deal. Hyper 8.5 pro, Novarossi 821 Modified, Jammin Jp4 pipe, painted body for $625.
as many people might know I was stuck trying to find a buggy for months, rc8, hyper, rc8,hyper, xray 808, etc, etc. it went back and forth, I finally bought the buggy and am happy now, I looked it over and like the design, I have seen them in action and I KNOW they are durable.
I say go with the hyper 8.5 pro and don't wait for anythign else, Xray 808, $599 pricey and if dont have one ordered yet, you won't see one till late july, but they are AMAZING buggies. RC8,$469, getting there, AE has just announced big bore shocks for it and will be releasing a new tank for it. Hyper 8.5 pro,$399, prob the best bang for the buck, yea the hyper 9 is coming out but give it a few months on the market, Mugen MBX5R its a mugen, old buggy, still winning and still a tank....what more can i say? also a bit pricey $550, but a new buggy has been announced. Kyosho 777, $alot, this thing jumped and cleareda house and didnt break, umm durable? i think so, also a proven winner, BUT kyosho has the new MP9 coming out soon.
When I picked up my buggy, the shop owner told me that today is not like it was a few years ago where mugen and kyosho dominated everything in every category, today anything you get is built alot better than it used to be and can win and last a long time.
umm...Im tired of typing.
Edit:
BTW, I went with an Ace DS 1015 servo (200oz .10sec) for steering and an Ace DS1313 (173oz .13 sec) for throttle, I know the 173oz is overkill for throttle, but I didn't realize this until I bought it, but these servos are great servos for under $100.
Edit #2:
Also remember this, you can make a fast servo slower, but you can't make a slow servo faster...
and what pipe have you decided on? it comes with tires, but where are you running? if its a rough, dry track, get some crimefighters in XTR for tires, the stock hyper 8.5 pro tires will be bald slicks in a few laps.
cobra26 06-05-2008 09:55 AM
RE: Hyper 8.5
ORIGINAL: f575gtc
Edit:
Edit #2:
Thanks for your thoughts and insight. I have 3 buggies so it's not like Ineed a new one right away; however, you make a good point about letting 'em "get the bugs out for a few months" after it becomes available. Sure do want one, though!
Swingnamiss 06-06-2008 06:19 AM
RE: Hyper 8.5
Ok thank everyone for the replies but here's what I'm going to run
Hyper 8.5 Pro Kit
OFNA .21 8 Port Race Engine W/Rear Exhaust
Hitec HSC-5998 Servo
Hitec HS-645MG Servo
OFN10249 Starter Box
OFNA 12 Gel Cell Battery Charger for the OFN10249
OFN10202 (5 Cell Hump Pack)
MRC Super Brain 960 Charger for the OFN10202
Will this be a good setup for this car? Also where can I get a pre painted body for the 8.5?
Osirisf16 06-06-2008 06:34 AM
RE: Hyper 8.5
Good enough i think. About the body, i can't find any prepainted, only precut ones
f575gtc 06-06-2008 01:31 PM
RE: Hyper 8.5
do we have an official 8.5 pro thread here? if we do lets bring it back if not lets make one.
tommygun32 06-06-2008 01:59 PM
RE: Hyper 8.5
f575gtc....
Don't need a prepainted buggy dude. Take the shell it came with, buy 3 cans of your favorite color and go with a solid paint job if you don't want to spend the time and effort with stencils and stuff. I've seen solid pearl white, metal flake blue, black and chrome....all were awesome.
If you want to try your hand at painting, it's not that hard. Find a stencil set you like, ask questions and get on with it. You can check out my FIRST attempt at painting a shell in the "buggie pics" thread. Not the latest pages, back 2 or 3. Get alot of comments on it at the track:D. All that was done with spray cans, slightly modified stencils (originally, the stencils i had were for a Monster Truck Shell) and some free-hand stencils. Took me 2 days all in to sort out. Great satisfaction from it as well.
Congrats on your new 8.5 by the way...;)
f575gtc 06-06-2008 06:39 PM
RE: Hyper 8.5
whoa why are we turning this against me?
I never said get one with a prepainted body... the deal I got already included a painted body, I paitn my own bodies I have an air brush and compressor, this one came with a bdoy that was painted, Im not gonna say no...
also Osirisf16 they dont come pre-painted none of the 8.5 pro bodies are painted. the hobby shop where I bought mine opened up the 8.5 pro finished building it, put in an engine, and were selling it, I just happened to buy it, thats why the body was painted, but the buggy itself was brand new, never ran.
