RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   piston/sleeve (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7772023-piston-sleeve.html)
youwish16 07-25-2008 04:59 PM
piston/sleeve
can you swap different /piston sleeves in different motors if the have the same stroke and bore?
my motor has a stroke of 16.80 and a bore and 16.26, could i take a piston/sleeve set from another motor with these numbers?
the reason i ask is because i have a picco .21b(3 port) and its hard finding parts for this motor and i noticed that all of picco's .21 motors have the same bore and stroke.
Paradoxmaker 07-25-2008 07:00 PM
RE: piston/sleeve
ORIGINAL: youwish16
Maybe maybe not....
Even though the sizes may be the same, the inside of the engine case has ribbing on it that directs fuel to the sleeve ports. So even though the sleeve fits, the ribs may not line up where they should...
bud09 07-25-2008 07:27 PM
RE: piston/sleeve
email ofna to c.
youwish16 07-25-2008 08:05 PM
RE: piston/sleeve
when the time comes i will, but i dont need it right now. i was just wondering so i asked. btw ofna is pretty good about answering emails and such. i've emailed them before looking for a backplate for this motor
Thunderbird93 07-26-2008 08:43 PM
RE: piston/sleeve
Check the part numbers of the other .21s to see if the piston and sleeve numbers match. I just put a piston and sleeve in my Picco .26 Outlaw and they use the same piston and sleeve for the Picco .26 Max.
