RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   will this battery work (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7923481-will-battery-work.html)
jamstar47 09-05-2008 03:10 PM
will this battery work and will it charge with the normal battery charger http://www3.towerhobbies.com/cgi-bin...8&I=LXRMR3&P=K
hrdcoreglf 09-05-2008 04:33 PM
RE: will this battery work
Yes that is a good receiver batt, but what do you mean by a normal charger? You can buy the Profit Plus for around $25 dollars and that will charge it with three different settings and will trickle charge so the battery is ready when you need it. It also keeps from over charging.
jamstar47 09-05-2008 06:59 PM
this is what i mean by a normal charger http://www3.towerhobbies.com/cgi-bin...&I=LXJC34&P=ML
K_B 09-05-2008 07:27 PM
From Tower Hobbies description for that charger:
**This charges at a 5A rate and is NOT recommended for charging NiMH batteries. The charge rate is not adjustable on this model.**
It's best to use a peak charger.
http://www3.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
That battery is also meant for the 5B so it has that Tamiya plug on it. I'm curious as to whether that battery is actually made of 2/3A cells or the bigger 4/5C cells which are bigger and won't fit in the radio box...
jamstar47 09-05-2008 07:30 PM
i dont have to put it in the radio box i can strap it down beside the radio box
jamstar47 09-05-2008 07:33 PM
then is are these good ? http://www3.towerhobbies.com/cgi-bin...?&I=LXMUE0&P=7
http://www3.towerhobbies.com/cgi-bin...8&I=LXLX84&P=K
K_B 09-05-2008 07:34 PM
Whatever floats your boat I guess....
jamstar47 09-05-2008 10:04 PM
but will they last for more than 2 hours or will a lipo be better
