RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   8ight diff. oil??? (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/7986122-8ight-diff-oil.html)
1cougar1 09-24-2008 11:02 AM
8ight diff. oil???
hello everyone, maybe you experienced guys could help me out. im going to be up-grading my diff. fluids and was wondering what grade(i think thats the proper term) oil i should get for the rear, center, front(is that the right order for explaining what grade oil to use). im really into my 8ight buggy. ill be bashing, and racing w/friends if that matters. some info would really help cause ive never changed my diff. fluids before thanx, clay unruh
youwish16 09-24-2008 11:17 AM
RE: 8ight diff. oil???
it depends on how you driver, what your driving on and how you like it to feel while driving. right now my eight is set up 5/2/3(f/m/r). losi stock set up is 7/5/2(i think)
rccheech 09-24-2008 11:35 AM
5/7/2 is a good starting point.
FoamyVictim 09-24-2008 01:23 PM
5/7/2 is a good starting point, but if you want more steering(like me) try 5/5/2. Lots of on power steering, and plenty of corner speed. I made that suggestion to a fellow 8ight racer... we both love it! ;)
rccheech 09-24-2008 01:28 PM
My personal preferance is 7/10/3.
K_B 09-24-2008 01:53 PM
ORIGINAL: FoamyVictim
I should have messed with that this last weekend. I had a helluva time coming onto the straightaway under full power without coming dangerously close to clipping the pit ramp :)
Losi Racer 09-24-2008 01:59 PM
whats the best way 2 remove the old fluid?? i used a rag and wiped most of it out but there was still some in there
hrdcoreglf 09-24-2008 02:05 PM
It has a lot to do with the surface you are driving on. I run a Jammin X1 on packed clay tracks. I have been running 5F-7C-3R. The thicker or heavier weight the oil the more unified the axles will turn.
1cougar1 09-24-2008 02:16 PM
thanx dudes, all that info will be very helpful. those are some pretty low numbers. isnt the highest grade like 50,000 or somthing. i wonder what that is like/ thanx agian, clay
FoamyVictim 09-24-2008 04:02 PM
Try it; it really helps the car rotate under power. We race on hard packed clay, and the layouts are all pretty tight and technical. So I needed something that I could sling into a corner, and power out of quickly. If they were long sweepers with lots of air(like a typical big 8th scale track) then 5/7/2 is a little easier.
