RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   HELP!!!!!!! (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/8104883-help.html)
DS 11-01-2008 12:59 PM
HELP!!!!!!!
Well did about 5 tanks and it is serousily bogging, here is the vid. When i lean the high the engine revs high. Take a look
http://www.youtube.com/watch?v=amkSVKgSuJI
supermod 11-01-2008 02:57 PM
RE: HELP!!!!!!!
replace your plug and then lean out your low speed needle a 1/4 turn..you are exprencing low end bog,shes too rich,if a quarter doesent work try a half a turn.;)
46u 11-01-2008 03:12 PM
RE: HELP!!!!!!!
When you lean the HSN did you try lowering the idle? You want to get the HSN very close before you start adjusting the LSN as the HSN affects the LSN.
