***OFFICIAL 2009 CASTER RACING ZX1.5R***
and so it begins............
RE: ***OFFICIAL 2009 CASTER RACING ZX1.5R***
awe man[:@] your trying to phase my baby out, my ZX1-R by making a new thread?[:o][:o] Hurry up and get them so I can get some pics up of mine when I get it.
what is the 1.5?
1 Attachment(s)
this is it...
1 Attachment(s)
Here is another pic. I like the stand up servo better and front shock tower.
1 Attachment(s)
Pics of a UK based ZX1.5R
...theres that associated pipe again...
Well it is finally available. Should be ordering 3 tonight and of course one of those is for me!
CAN'T WAIT!!!!!!!!!!!!!!
ORIGINAL: ASATRUGGYFAN CAN'T WAIT!!!!!!!!!!!!!! |
yup, gotta love sitting in the middle of the living room holding tools and being surrounded by 78 small bags of parts for 8 hours straight. but whats cool is you can do all your "little stuff" to it along the way.
Well, it seemed the concensus of the R/C world was that everyone wished for kits again.....Of course, we listen to our customers and make it happen.
It was. I am actually looking forward to it more since I have to build it! Thought I would get it today but nothing showed up, oh well. Will be waiting like a little kid on Monday!
Well it finally arrived today! Kit is pretty sweet and well organized. Will be posting pics of the build soon! I love the bottom of the Chassis, it has engraved in huge letters ZX1.5R.
I am at work right now but can post pics later this evening. This thing is sweet. The diff gears look WAY BETTER and are slightly bevel cut ring and pinions. NO NEED FOR SHIMMING the diff in the bulkhead, FITS PERFECT. The ring and pinions are so smooth now it ain't even funny. The outdrives look the same but the shafts that go into the diff case are slight shorter and also the pinion gear looks like the toughest one I have ever seen, Also is lighter too with a huge hole drilled in the center. Front shock tower is alot shorter therefore you can get alot more droop and the holes are alot closer together which will lay the shocks down more. Servo saver threads are alot more course and will prevent stripping of it like what was easy to do on the previous model. Hinge pins look alot harder and are different color. Steering rod ends are captured and the plastic ball end is way thicker and stronger so should not break anymore. Also no need to put spacers under the ackerman plate ball or knuckle one to get rid of bumpsteer as the new captured ones sit on a post and automatically to this for you. That is all I can see as of now. I will post more later as I find out.
ORIGINAL: vnmsgt Well it finally arrived today! Kit is pretty sweet and well organized. Will be posting pics of the build soon! I love the bottom of the Chassis, it has engraved in huge letters ZX1.5R. guess i have to wait to see it in 2 weeks then. |
1 Attachment(s)
Well here are some pics. Other things I noticed are it now comes with a Oval Air filter and it also comes with ferodo brake discs and brake free springs to keep the pads away from the disc.
1 Attachment(s)
Also after installing the shocks I found out it has way more front droop than the ZX1-R because of how much shorter the shock towers are. The new towers will bolt onto the old ZX1-R if you wanted to upgrade too. Here are more pics.
1 Attachment(s)
And more pics.....
beautiful. new diffs, new o-rings, new crown/pinion, new radio tray, new shock towers, new blocks, new hinge pins, how about new more durable outdrives? looks like more than a 1.5 upgrade kit is needed. with more droop don't we loose steering, i remember i had to remove droop to get them wheels to come around. the build is beautiful but we want to see the drive.
ORIGINAL: j_blaze beautiful. new diffs, new o-rings, new crown/pinion, new radio tray, new shock towers, new blocks, new hinge pins, how about new more durable outdrives? looks like more than a 1.5 upgrade kit is needed. with more droop don't we loose steering, i remember i had to remove droop to get them wheels to come around. the build is beautiful but we want to see the drive. |
1 Attachment(s)
Here are some more pics of the 1.5R almost done!
Nice looking bug how much does it weigh race ready?
ORIGINAL: 46u Nice looking bug how much does it weigh race ready? |
hey chris. nice build, the buggy looks amazing. Could you take pics of the differance in front droop so i can see if it is worth upgrading???thanks man:D
