RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Hyper 7 weak points (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/8268425-hyper-7-weak-points.html)
GTee 12-21-2008 05:33 PM
Hyper 7 weak points
In the new year I will be getting a Hyper 7 TQ Black and I want to stock up on parts that I am likely brake, what are the parts do the hypers go through the most? I know from the days that I had a Savage I went through loads of pull starts difs and spur gears.
Also I have heard that the engine in the TQ Black needs more maintenance, what is meant by this.
nissan300ztt 12-21-2008 09:42 PM
RE: Hyper 7 weak points
Well man I have a hyper 7 Tq black edition and I must say i beat on it. And the only thing I can say is go to nitrohouse and get the paulcoleman racing parts. And stock up on tires and wing mounts and wings. And always keep some extra crown gears and clutch bells. Thats pretty much it. Most of the modern buggies are pretty well built.
Dokioto 12-22-2008 03:10 AM
It's a solid car.. I would stock up on turn buckles and buy a nice servo.
mogi 12-22-2008 04:10 AM
the front cast c hubs break,get some cnc ones and your good to go, very tough buggy mate you will love it...
Dokioto 12-22-2008 05:38 AM
Really? You must of been in a big crash! Mine seem tougher than nails.
zjwhitrock 12-22-2008 10:50 AM
servos, get decent servos, If your short on $$ hs645s will work
stz28 12-22-2008 12:31 PM
Buy some spare center chassis braces, also the long screw that holds the rear brace in place.
I would also get an extra motor mount and a rear wing. The mount won't break, but the bottom holes will eventually strip out.
Hope this helps.
My Name Is Brad 12-22-2008 01:15 PM
My friend has one. I would buy a stronger steering servo (the stock one is pathetic), spare clutchbell/shoes, and obviously get quite a few glowplugs as those go very fast during breakin.
good luck
GTee 12-22-2008 06:18 PM
Thanks guys,
Will all the parts for the Hyper 7 fit the 'TQ Black' and does anybody have an exploded diagram for it?
Cheers
nissan300ztt 12-22-2008 06:23 PM
If you look at the TQ on ONFAs website. There is a "kit" manual its got all the views youll need.
ace9213 12-22-2008 11:16 PM
get servos! and do it right. get high torque and hi speed!
