RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Oversteer on high-grip surfaces (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/8660498-oversteer-high-grip-surfaces.html)
Argess 04-08-2009 06:16 AM
My buggy can drift corners nicely on very loose surfaces, but on asphalt it likes to do a 180 "VERY" easily. I suspect a toe-in adjustment might help. I was thinking of reducing the front toe-out, or increasing the rear toe-in.
It has no center differential, and the front and rear arn't designed to hold oil, so nothing I can do there.
There are lots of other adjustments such as shocks, swaybars, etc, but it doesn't appear to be suffering from a roll issue.
Any thoughts on the problem?
tommygun32 04-08-2009 08:16 AM
RE: Oversteer on high-grip surfaces
Don't know about the toe-in's and toe-out's but thinking about the different surfaces your driving on would first make me think about a different set of tires?
Foxy 04-08-2009 08:25 AM
Soften the rear suspension and remove any rear sway bar you have. Alternatively, stiffen the front end.
The rule of thumb for handling... To induce over or understeer, or correct either, you simply soften the suspension at the end you want to grip, or harden the suspension at the end you want less grip. This goes for almost all suspension adjustments, spring rate, shock oil, sway bar thickness, camber.
You should definitely reduce front toe-out if you have a lot, but increasing rear toe-in won't help much. Consider lowering the car when running on asphalt, and increase rear droop.
tommygun32 04-08-2009 08:37 AM
Thanks Foxy, that's good info.
Argess 04-08-2009 10:21 AM
Yes, thank-you. Makes sense, and I'll try those things.
SManMTB 04-09-2009 06:55 PM
There are so many things to do.
A softer rear sway bar is an easy change. If you don't have one just tighten up the front one a few mm.
Softer rear end suspension is another thing to test.
Lower the rear ride height slightly.
Rear camber link in a lower position.
Lighter diff oil in the rear.
Changing the rear toe to 2 deg from 3deg makes the car more predictive in handling. It doesn't loose grip suddenly but more gradual. It can make it feel easier to drive on the edge.
Argess 04-10-2009 06:30 AM
Thank-you...lots of stuff to try. Im sure I will get improvement sooner or later....LOL.
