RCU Forums
-   RC 1/8th Scale Buggies (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/)
-   -   Your BUGGY and SETUP (https://www.rcuniverse.com/forum/rc-1-8th-scale-buggies-244/8757918-your-buggy-setup.html)
JsK 05-10-2009 08:07 PM
Copied this from the Truggy forum where its a Sticky, great idea maybe we
can get this going here and the Mods will sticky it
Ok Lets hope this thread works and for once put an end to all the most commonly asked questions about what setup, what diffs, what servos. I'm sure I'm missing a lot of specs but thats all I can think of right now so feel free to add a spec or two in your data.
Let me start it off:
Here's the blank template you can copy n' paste this with your info in it:
BUGGY :
THR SERVO :
STR SERVO :
MOTOR :
PIPE :
RADIO :
CLUTCH :
CB :
WHEELS :
DIFFS F/C/R :
SPRINGS F/R:
SHOCKS F/R :
DROOP F/R :
RIDE HEIGHT :
CAMBER F/R :
WING:
ADD INFO MODS ECT:
TRACK READY WEIGHT:
Here's my configuration:
BUGGY : AE RC8
THR SERVO : AE 1015
STR SERVO : AE 1015
MOTOR : OS V-Spec
PIPE : TT 2035
RADIO : SP DX3
CLUTCH : JP ALUM 1 BLACK 2 GOLD SPRINGS
CB : 16T
WHEELS : MP9 OR LOSI
TIRES F/R : AKA CITY BOCKS SOFT OR IBEAMS IN SOFT, AKA INSERTS
DIFFS F/C/R : 5/5/5
BARS F/R : SILVER/SILVER
SPRINGS F/R: SILVER/SILVER
SHOCKS F/R : 1.4X2 1.2X2 PISTONS FRONT AND REAR, 40WT BELOW 70F, 45WT 70F-90F MAYBE 50WT IF ITS BLAZING OUT
DROOP F/R : NONE, SHOCKS HAVE 2MM FRONT AND 5MM REAR LIMITERS
RIDE HEIGHT : 29MM/29MM RC8s are very sensitive move slowly in 1/2 mm increments
CAMBER F/R : -1.5/-1.5
WHEELBASE : MEDIUM
CASTER F/R : 16
TOE F/R : +1 / -3
WING: FORWARD AND LOW, STOCK AE
ADD INFO MODS ECT: RX BATTERY RELOCATION, EMULSION SHOCKS WHITH RTR CAPS, STEERING MOD.
HINGE PIN BUSHING 1F/2R DOWN, KICKUP 2UP, ANTISQUAT 3DOWN.
TRACK READY WEIGHT: 3705 GRAMS
This is all pretty simular to the last Team Setup before they went to Big Bores.
youwish16 05-10-2009 08:38 PM
RE: Your BUGGY and SETUP
BUGGY : Losi 8ight 1.0
THR SERVO : Ace DS1313
STR SERVO : Ace DS1313
MOTOR : RB S3 L2G
PIPE : Dynamite Header, Sportwerks HT Pipe
RADIO : Spektrum dx3s
CLUTCH : 3 shoe, 1.0 springs, Alumin Dynamite Max Life Shoes
CB : Ofna 14t Vented
WHEELS : Whatever i can get
DIFFS F/C/R : either 5,7,2 5,5,2 or 5,3,2...5,5,2 right now
SPRINGS F/R: Silver Front, Green Rear
SHOCKS F/R : 35wt all the way around
DROOP F/R : varies
RIDE HEIGHT : varies
CAMBER F/R : varies
TOE F/R : +2, -2
WING: JConcepts
ADD INFO MODS ECT:
no sway bar in front or rear
dynamite blue aluminum servo arms
DrDremel 05-10-2009 10:01 PM
BUGGY : AE RC8
THR SERVO : Futaba S3003
STR SERVO : Hitec 7965MG
MOTOR : OS V-Spec
PIPE : Jammin JP-4
RADIO : Futaba 3pm 2.4ghz
CLUTCH : Mugen 3-shoe composite clutch shoes w/ 1.0 springs
CB : Mugen 14t
WHEELS : Pro-Line
TIRES F/R : Crimefighter M2-M3 or Holeshot M2-M3
DIFFS F/C/R : 7/7/3
SPRINGS F/R: Bronze/Silver
SHOCKS F/R : 1.4X2 1.2X2 PISTONS FRONT AND REAR, 30WT All around
DROOP F/R : NONE
WHEELBASE : MEDIUM
CASTER F/R : 16
TOE F/R : +1 / -2
ADD INFO MODS ECT: RX BATTERY RELOCATION, BIG BORE SHOCKS, STEERING MOD.
Chris_RC 05-10-2009 10:23 PM
BUGGY : 8ight 1.5
THR SERVO : Airtronics 94357
STR SERVO : Hitec 7955TG
MOTOR : OS V-Spec/Mach 427
PIPE : JP-3
RADIO : DX2.0
CLUTCH : Losi, 2 MaxLife, 2 carbon, black and green springs
CB : 13T Losi
WHEELS : AKA or Proline
TIRES F/R: M3 Holeshot, soft city-beam
DIFFS F/C/R : 3-5-2
SPRINGS F/R: silver green
SHOCKS F/R : 40-25 54-56 pistons
DROOP F/R : 95-106
RIDE HEIGHT : 27mm front, 29mm rear
CAMBER F/R : -1, -1.5
WING: stock losi black
ADD INFO MODS ECT: Xtreme Carbon Fiber radio Stiffener, dynamite red aluminum servo horn, and wrap on body.
EDIT: made quite a few changes.
JsK 05-10-2009 10:48 PM
Dr your kidding right, a 14t clutchbell[X(]
DrDremel 05-10-2009 11:58 PM
Works wonders for me :D
Dirtdigger04 05-11-2009 12:10 AM
BUGGY : Sportwerks Mayhem
THR SERVO : Hitec HS-325HB
STR SERVO : Futaba S3305
MOTOR : LRP .28 Spec 3
PIPE : Jammin JP2
RADIO : JR XR3i
CLUTCH : 3 shoe, 1.0 springs, Aluminum Ofna Blue
CB : Axial 15 tooth
WHEELS : Proline Dish
TIRES : Proline Knuckles 2.0
SPRINGS F/R: Black
WING: Stock Mayhem
ADD INFO MODS ECT:
Venom failsafe
CV boots
kojak61 05-11-2009 01:30 PM
BUGGY : Hot Bodies D8
THR SERVO : Hitec 5625
STR SERVO :Hitec 7955
MOTOR : OS VZ-B Vspec T
PIPE : Dynamite 007HT
RADIO : M8 with Spectrum Pro
CLUTCH : stock
CB : stock 16
WHEELS : AKA
DIFFS F/C/R : 5-4-1
SPRINGS F/R: White/White
SHOCKS F/R : 1.3 400/1.3 450
DROOP F/R : 97/98
RIDE HEIGHT :28/30
CAMBER F/R : 1/2
WING: stock
ADD INFO MODS ECT:
Vspec has TKO ceramic bearing. Aluminum servo horn on steering servo.
cod 05-11-2009 06:07 PM
BUGGY : Losi Eight 1.0
THR SERVO:ACE DS 1015
STR SERVO : HITEC 5997 TG
MOTOR : OS SPEED ALU HEAD
PIPE : HN EFRA 2047
RADIO : FUTABA 4PK
CLUTCH : LOSI, 2 ALU SHOES SILVER SRINGS, 2 COMPOSITE SHOES GOLD SPRINGS
CB : ANSWER RC 13T
WHEELS : LOSI OR PROLINE
DIFFS F/C/R : 5/7/2
SPRINGS F/R: F,SILVER R,GREEN
SHOCKS F/R : 35/32.5 54/55 PISTONS
DROOP F/R : 95/106
RIDE HEIGHT : 27/29
CAMBER F/R : -2/-3
WING: LOSI
ADD INFO MODS ECT: FIRONI RADIO TRAY STIFFENER, ALU SERVO SAVER TOP, ANSWER RC BEARINGS ALL ROUND, LOSI ALU SERVO HORN
cod 05-11-2009 06:13 PM
1 Attachment(s)
Oh also losi 2.0 upgrades! arms, rear hubs, shock towers and tank
Pathous 05-11-2009 07:14 PM
THR SERVO : 7985
STR SERVO : 7955
MOTOR : Ninja JX21
PIPE : Jp 4
RADIO : DX 3R
CLUTCH : Stock
CB : 16
WHEELS : AKA
DIFFS F/C/R : 10/10/4
SPRINGS F/R: White/Green 68mm
SHOCKS F/R : 40/45
DROOP F/R : 99/100
RIDE HEIGHT : 29/30
CAMBER F/R : -1/-2
WING: Proline
WB Alum shock towers and lightened chassis.
bweiler 05-11-2009 07:36 PM
BUGGY : CEN Matrix C2
THR SERVO : Stock
STR SERVO : ACE 1015
MOTOR : SH .28 w/backplate & .1mm shim for 30%
PIPE : JP-6
RADIO : Stock Sanwa MX3 FM
CLUTCH : OFNA 3 Aluminum shoes, 1.1mm springs
CB : OFNA 13T
WHEELS : AKA
TIRES F/R : Worn AKA City Blocks or Worn Proline Crimefighters
DIFFS F/C/R : 3/5/2
BARS F/R : Stock
SPRINGS F/R: Stock Blue
SHOCKS F/R : 40wt/30wt
DROOP F/R : Have the 5mm spacers on all shocks
RIDE HEIGHT : F - Bones above, R - Bones slightly above
CAMBER F/R : -2/-2
WHEELBASE : Stock
CASTER F/R : Stock
TOE F/R : +1, -3
WING: Bent (badly)
ADD INFO MODS ECT: 3' toe/3' antisquat aluminum. Aluminum servo saver, Truggy tank, Low profile air filter, Kyosho servo bar parts, Advantage fiberglass brakes, Traxxus antenna tube (not a trivial thing).
musclecar64 05-15-2009 07:39 PM
BUGGY : Team Associated RC8 FT
THR SERVO : Associated DS1015
STR SERVO : Associated DS1015
MOTOR : O.S. V-spec
PIPE : JP-3
RADIO : DX3R
CLUTCH : Stock AE clutch with Impulse-RC Hard (2024) Aluminum shoes and 1.0mm springs
CB : Stock AE 16T
WHEELS : Proline or AE, White
TIRES: Holeshot M3, Crimefighter M2, Switch 2.0 Clay
DIFFS F/C/R : 5K, 5K, 5K
BARS F/R: Silver Front/Gold Rear
SPRINGS F/R: Front- OFNA 16mm Blue/Rear- OFNA 16mm White
SHOCKS F/R : 35wt oil F+R, Holes: 1.2x6 Front/1.4x6 Rear (AE big bores F+R)
DROOP F/R : No droop, 2mm internal limiting front/4mm internal limiting Rear, otherwise F+R shocks at stock lengths
RIDE HEIGHT : 29mm F+R (varies)
CAMBER F/R : -2 F+R
WHEELBASE: Medium
CASTER: 16
TOE F/R: 1 Out Front/3 In Rear
WING: Back and Low, AE White
ADD INFO MODS ECT: setup based on Cavalieri 2008 The Dirt Nitro Challenge setup, big bores, updated steering mod, AE Aluminum Top Plate,
AE updated fuel tank, Jconcepts Illuzion Body, Powersave airfilter elements and UndergroundRC prefilter cover, Impulse-RC clutch shoes
RTR chassis braces (still flexes, won't break like FT stock) AVID and Boca Bearings (steel)
JsK 06-24-2009 08:12 PM
Gonna bump this and add weight to the list. Please just leave it blank if you don't
have a scale so we don't end up with a bunch of guesses. True track ready weights please.
Gonna have to PM Foxy to see if he will sticky it for us.
kojak61 06-24-2009 08:22 PM
PIPE : OS Engines 2050
RADIO : DX3R
CLUTCH : stock
CB : stock 16
WHEELS : AKA
DIFFS F/C/R : 5-4-1
DROOP F/R : 97/98
RIDE HEIGHT :28/30
CAMBER F/R : 1/2
WING: stock
Weight: ?
ADD INFO MODS ECT:
Snaut Rocket 06-24-2009 10:19 PM
BUGGY : Caster Fusion pro
THR SERVO :mmm v3
STR SERVO : hitec ultra torq
MOTOR :Medusa V2 2000kv
PIPE : True rc lipos.
RADIO :airtronics mx3 fhss
CLUTCH : none
CB :13 t
WHEELS : bow ties
DIFFS F/C/R : 10 30 10
SPRINGS F/R:stiff, stiff
SHOCKS F/R :40wt
DROOP F/R :
RIDE HEIGHT :
CAMBER F/R :
WING: stock
rccheech 06-25-2009 05:05 PM
THR SERVO : Hitec 7955mg
STR SERVO : Airtronics 94780mg
MOTOR : RB C6BBTII, RB S7, GO 5P
PIPE : Jammin JP-4
RADIO : JRXR3 (I know, it's old)
CLUTCH :4 silver springs, losi long wear alum.
CB : Varies...13t now
WHEELS : Depending on track condition, usually JC double dees
DIFFS F/C/R : 5,5,2 -current
SPRINGS F/R:Gray, Green
SHOCKS F/R : 40wt 55 piston, 35wt 56 piston
DROOP F/R : 103mm
RIDE HEIGHT : 29.5 mm front 30mm rear- current
CAMBER F/R : -2,-2
TOE F/R -2, +2
WING: Stock
ADD INFO MODS ECT:TFT Chassis, aluminium knuckles and carriers, aluminium servo saver top, aluminium st servo horn.
TRACK READY WEIGHT: not sure
timberone 07-01-2009 03:03 PM
THR SERVO : Hitec 965MG
MOTOR : GRP .21 Tuned & Modded/OS Vspec backup motor
PIPE : Varies - Dynamite torque, mid-range and high speed
RADIO : DX3R
CLUTCH : Losi, 2 Soft Alum w/ gold springs, 2 carbon w/ green springs
CB : 13T or 14T Losi
WHEELS : Proline Velocity
TIRES F/R: Bow-Tie V2-M3 or Bow-tie V3-M3
DIFFS F/C/R : 7-5-3
SPRINGS F/R: F-Silver, R-Green
SHOCKS F/R : F-35wt, R-27.5wt
DROOP F/R : Varies
CAMBER F/R : -1.5, -2
WING: ProLine Hi-downforce
ADD INFO MODS ECT: King Headz radio stiffener, Lunsford titanium tie-rods & pins, ProTek Ceramic Bearing Kit, TKO Ceramic Bearings in both engines, Switched to a RTR chassis because the pro chassis had too much flex
Chris_RC 07-01-2009 10:07 PM
Why would you not want flex? The RTR chassis is horriblly stiff and inconsistent.
djzachtyler 07-01-2009 10:34 PM
1 Attachment(s)
BUGGY : HoBao Hyper 7
THR SERVO : HiTec 625MG super torque
STR SERVO : HiTec 645MG ultra torque
MOTOR : Hyper .21 3port Turbo
PIPE : Hyper polished exhaust
RADIO : Spektrum DX3S w SR3300T rx
CLUTCH : Hyper7 with aluminum shoes
CB : 12 t
WHEELS : ProLine Crimefigter tires on green 5 spoke wheels
DIFFS F/C/R : 7-10-3
SPRINGS F/R: yellow race
SHOCKS F/R : aftermarket full aluminum adjustable
WING: HiMoto High downforce wing
McWolf_101 03-18-2010 03:13 PM
<span style="font-size: small;"><span style="font-family: Comic Sans MS;">I do not have a buggy as yet but I believe that this thread is a helpful guide and should be re-visited. Please, continue posting. http://www.rcuniverse.com/forum/js/f...ular_smile.gif</span></span>
The_Shark 03-18-2010 05:17 PM
BUGGY : ofna 9.5
THR SERVO : hitec 645MG
STR SERVO : hitec 645mg
MOTOR : Jammin JPX .21
PIPE : Jammin JP-2
RADIO : Futaba 2pL (digital end point ect)
CLUTCH : OFNA purple aluminum with black springs
CB : 15T
WHEELS : Panthers- soft
DIFFS F/C/R : 7K 10K 2K hardend gears all around.
SPRINGS F/R: red/red
SHOCKS F/R : Jammin big bore 35F 30R
DROOP F/R : ??? 7mm angle down on front
RIDE HEIGHT : level on rear control arms, slight droop on front.
CAMBER F/R : F -2 R -1
WING: proline high downforce.
ADD INFO MODS ECT: upgraded Front and rear pillow ball suspension, alumnium servo posts, aluminum braces, alu servo horn
TRACK READY WEIGHT: 8.7lbs (full tank, 4 AA's body ect)
Great idea JSK. let me add Toe:D
TOE: +4 total front -3 total rear
kojak61 03-18-2010 07:26 PM
Update
MOTOR : Novarossi N21R HotMods Modded
RADIO : DX3R
CLUTCH : Dynamite long life aluminum
CB : stock 16
WHEELS : AKA
DIFFS F/C/R : 4-4-2
DROOP F/R : 97/98
RIDE HEIGHT :28/30
CAMBER F/R : 1/2
WING: stock
Weight: ?
ADD INFO MODS ECT:
Vspec has TKO ceramic bearing. Aluminum servo horn on steering servo. lightweight brake cams
The_Shark 03-21-2010 12:08 PM
im curious to see what everyone's rig weighs! mine is like a tank.
kojak61 03-25-2010 09:50 PM
Update
RADIO : DX3R
CLUTCH : stock
CB : stock 16
WHEELS : AKA
DIFFS F/C/R : 4-4-2
DROOP F/R : 97/98
RIDE HEIGHT :28/30
CAMBER F/R : 1/2
WING: stock
Weight: ?
ADD INFO MODS ECT:
