New build 3pt wlc-isetta
Below pics of some of my airboats.
I do not know if I like to navigate or build more, but just know that I am uneasy when I do not mess in the service area away from home and not leave my wife quiet.
the last hydrofoil was a copy of our friend self, my excuses, but it is an interesting model.
I began to call him wlc isetta therefore reminds me ........romisetta.
pics romisetta
pics romisetta
FL
RE: New build 3pt wlc-isetta
Looking good Carlosam. Want another friend. Your boat should really fly. Make sure you have a good turn fin and a way to retrieve a flipped over boat. The SI3 boats are very fast, but tend to get loose in the corners. Put up some video if you can. They are always fun to watch.
ORIGINAL: DJLaPalme
Unfortunately might take a while, because I intend to put an ASP 52.
As well as the wlc-law, this boat was not made ​​with plans but with a good sense of measures and proportions, having been with
750mm long , 560mm width and 50mm skis.
Naval plywood was used in the construction of 4 and 6 mm.
Its total weight without motor,tank and electronic is 1930 grams.
Regarding the ASP 52 - a great budget engine, powerful and easy to start.
Just note they can take a bit of time to run in.
You will not get a very good transition when breaking in, and be carefull with the screws that mount the carb - they can strip very easily.
ORIGINAL: dadkins
That is a cute little fuel filter you got there - also why so much battery ?
This airboat is what I did for my friend, my is still waiting for the completion of another project.
My friend has some fast electric boats and I encouraged him to get in on the airboat.
As he has several lipo batteries, he decided to use that was not in use to have little mah.
Protection of the propeller or the protection of fingers and hands.
Excellent idea and should be used as security.My friend has cut his finger in the propeller
I believe that with the pics to protect the propeller, some airboats manufacturers, in their posts will encourage the use of protection.
That would be the minimum to be done.
Go a few more pics below.
