Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
lets try this again foam build help
RC Airboats Discuss R/C Airboats here!
Old 01-24-2013, 04:59 AM
yellowufo
Default lets try this again foam build help
Any thoughts on a first foam air boat build ie glue foam to foam, glue for wood to foam tricks typs of glue
epoxys?
Old 01-24-2013, 06:45 AM
dadkins
Default RE: lets try this again foam build help
I have had the best luck with regular gorrilla glue for foam to foam and foam to wood - dont use the quick set clear stuff - not as good a bond. moisten your parts first and use moderate clamping pressure so the parts dont expand, it kind of foams up and expands when its curing. then you can cut and sand off the excess. epoxy works ok too for quick fixes but the gorilla bonds to the foam like nothing else.
Old 01-24-2013, 06:49 AM
dadkins
Wood over foam.
ID:	1843829   Click image for larger version
ID:	1843830   Click image for larger version
ID:	1843831   Click image for larger version
ID:	1843832   Click image for larger version
Old 01-24-2013, 10:48 AM
yellowufo
ORIGINAL: dadkins
Wood over foam.
Old 01-24-2013, 01:53 PM
rcairboater
ORIGINAL: yellowufo
epoxys?
Use the blue dow board from the lumber yard. Sometimes it's pink as well. Peel off the plastic film from the foam
and it's good to glue up. You can use a slow set epoxy 45 minute to glue up foam to foam or wood to foam.
Use the epoxy lite as you don't need much. If using wood over the foam, use 1/16" ply on the bottom and sides.
Clamp and or tape real good until the epoxy dries. Then fill any gaps with a epoxy and add baby powder to thicken it up to your liking.
The baby powder acts as a suspender for the epoxy.
Thanks.
Old 02-02-2013, 08:18 PM
yellowufo
My boat was a pre cut kit it is compleat now cept for motor and prop thanks for the advise all
Old 02-07-2013, 06:41 PM
yellowufo
Well i finished my build it is way underpowerd but will cruise on water and on snow and across carpet with a swift push when i go lipo and step up to a 2200 kv it will fly over anything im at 980 kv and nimh right now using a 1/16 mini traxxas electrronics so the 980 was all i could do i have a 7.5 prop but will try a 7.6 soon hope for a little ice to try it on soon try this little drifter airboat foam build it is a fun build
Old 02-12-2013, 09:34 PM
yellowufo
Got the 7.6 prop and wow what a differance it made got an 8.8 but i think its to much prop besides being to large
It going back for a receiver plug and a red and green led
Old 02-13-2013, 02:48 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Any pics of your creation?
Old 02-13-2013, 05:00 AM
yellowufo
ORIGINAL: 1QwkSport2.5r
Since im on a tablet i cant seem to post pics yet but it can b seen at ( aero surface drifter) minus the uscg stickers its the same kit i built
Old 02-13-2013, 05:34 AM
yellowufo
If you look at my profile in the gallery there is a pic of the boat, best i can do for pics right now.
Old 02-13-2013, 02:49 PM
vicman
My Feedback: (10)
vicman's Avatar
That looks pretty good!
Any reason you want to cover it?
I second using gorilla glue. I also have a vac bag, that makes skinning foam super easy.
Old 02-13-2013, 03:23 PM
yellowufo
ORIGINAL: vicman
NOt going to cover the concept with this boat is light weight. I just put some packing tape on the bottom to protect it from pavment rash i put a 8,8 prop on today and it has way more thrust will run it on water tomorrow the 7.6 was faster but still not fast enough. The need for foam to wood epoxy was the motor mount
Old 02-13-2013, 06:24 PM
vicman
My Feedback: (10)
vicman's Avatar
Oops, cover was the wrong word I guess. I meant why are you skinning (covering) the foam with wood?
I see you just wanted a good glue for fastening your mount. In that case I would have said dig a little hole and use gorilla glue.
Your project still looks pretty cool.
Old 02-14-2013, 05:22 AM
yellowufo
ORIGINAL: vicman
I did make a few under cuts in the foam so the epoxy would have a better grab on the foam yea my skinning is just tape this would bairly move if i added more weight to it
Old 02-14-2013, 04:59 PM
yellowufo
Videos posted on youtube in another post
Old 02-15-2013, 06:39 AM
yellowufo
I just boiled some water and layed the hull over the pot an wow all the dings and gouges r gone guess i need a steam iron now
