Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
SI 1/4 scale 3 pt hydro electric conversion.
RC Airboats Discuss R/C Airboats here!
Old 08-28-2015, 08:20 PM
  #51
1QwkSport2.5r
1QwkSport2.5r's Avatar
Wall climb! Wall climb!
Kidding aside, seeing Kurts boats run is impressive... That 1/4 scale machine is something to see run... My 3hp Jett doesn't even compare...
It's good to see you around again, Gary. How's the prototype coming along?
Old 08-30-2015, 01:51 PM
  #52
St.Marek
Hello.
When I've watching your video from swimming I recalled myself 0:35-0:41 of this film:
https://www.youtube.com/watch?v=hkuJ...cXT6sfHGkosFdg
It seems to me that bottoms of hulls must be diffrent because models starts to fly at high speeds. Interesting solution is this type of hull:
In your's model it can be possible to change the bottom shape of float hull ( i can't exactly define this element of model in english ) and right angle of engine tilt ( max -3 deg. ), and of course, very accurate ballancing of the model and it would be swim correctly.
Old 08-31-2015, 05:02 PM
  #53
hooty301
Yea I need too get them out, the electric has been sitting since its first time out.
Its ready too run, I've got new packs too, just waiting.
On yours
Id put two runners on the back of the tub, 1.25 or so wide. Get the boat where it's setting close too level when it's on a table.
Need dead calm water.
Old 09-01-2015, 12:30 PM
  #54
71dartswinger
The one that's in the air is Terry's fiberglass step hull its in the air because it was very windy that day motor is 50cc twin cyl
Old 09-07-2015, 07:34 PM
  #55
crispyspa
crispyspa's Avatar
I can truthfully say that this boat's quest for 70 mph is over....
https://www.youtube.com/watch?v=-NdaOVRS1B4
Old 09-08-2015, 11:36 AM
  #56
asmithnc
asmithnc's Avatar
Great post Kurt.....That motor makes the boat a formula 1 power house. Make the boat out of aluminum and carbon and remove that KILLER flex. keep watching the slo-mo over and over
Old 09-08-2015, 04:01 PM
  #57
1QwkSport2.5r
Major bummer Kurt. My thoughts are with you in this time of loss... At least you got the expensive bits back!!!
Did you find the GPS?
Old 09-08-2015, 07:52 PM
  #58
crispyspa
crispyspa's Avatar
I found everything, and everything works. *whew* For anyone wondering if the Forerunner 201 is truly waterproof, I can attest that it is. I've looked into a large enough sheet of carbon fiber to make the deck...that ain't happenin'. it's like $2300. I'll have to find some way to remove the flex. After thinking about it for a while, I'm convinced that the wood was really stressed from all the other crashes and it just decided to give up.
I've been eyeing up "overbite" SI3-G hull, It wouldn't take all that long to convert...
Old 09-08-2015, 08:14 PM
  #59
1QwkSport2.5r
I'd just build another one from regular birch plywood again. Golly, it survived this long.... Then again you did have two of those pigs...
What'd the GPS say the top speed was?
Old 09-09-2015, 08:20 AM
  #60
crispyspa
crispyspa's Avatar
65 mph. Very disappointing. There has to be a way to stiffen the top deck without adding a ton of weight. Maybe oak plywood?
Old 09-09-2015, 09:26 AM
  #61
1QwkSport2.5r
Oak plywood isn't any better. The oak veneer is so thin, it alone won't do much strength-wise. And quite possibly, the substrate could be pine and not a hardwood. I think you would need to do something similar to what I did on my 60 series copy with a couple sticks of oak.
Old 09-09-2015, 04:18 PM
  #62
hooty301
Wow man that was wild!
I can't believe you found everything like that.
Old 09-10-2015, 03:27 PM
  #63
pinky_d_brain
O snap man that sucks but a dame good fishing job my friend
Ever think about building your own hull design??
If you want you can build something like this
Its a concept sketch that I posted on RCAW and some gasser or 1/4 scale pontoon plans I did up. the concept was take the middle section and add it to the back of the out runners removing one point of contact. Put a wing on the back to keep the back stable at high speeds. one of the key things is bring the CG up so when you gun the throttle the boat wants to jump up instead of down allowing the boat to plane out. stiffness will be a problem but you could build a cat type hull to help. Anyway it would be fun to play with I wan to build a small one to see how it works and get the CG and things working.
File Type: pdf
File Type: pdf
Old 09-12-2015, 06:14 AM
  #64
St.Marek
Hello.
That crash is not nice for modeller. We've had a few incidents. I try to film every single swimming to analyse it after it. We've analysed your film and we're think that construction of Speed Airboat doesn't work well on high speeds- it gets vibrations ( as it was visible on film from 4:50 to 5:05 ).
Congratulations, you reclaimed all your gear. Some time ago we've lost to batteries in crash.
If you send us demensions of the model, power of the motor, betteries capacity and voltage, size of propeller we'll try to invent a new idea of that model.
