Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
1/5 scale airboat project
RC Airboats Discuss R/C Airboats here!
Old 03-02-2021, 03:15 AM
specialk1
specialk1's Avatar
Default 1/5 scale airboat project
Just picked this one up these hulls , they are made in Florida going to redo a few things on it. has slick bottom on it for sliding going to have to add a trim tab because it's porpoising . Waiting for some new LiPo battery trays so I can mount them and straighten out the CG a little bit. Next I'm going to build aluminum foils instead of the fiberglass ones that are on it now
Old 03-02-2021, 07:34 AM
Got RPM
Got RPM's Avatar
Nice boat. I assume you’ll raise the assembly and mount it on a deck, currently about 1/5 of the prop blast is shrouded by the transom and is working against you by drastically reducing thrust. What motor, ESC, battery and prop are you using? How long is the hull?
The porpoising could be due to the CG being too far back, or the hull design. Before adding tabs I’d recommend playing with the CG. Hulls like this usually work best with the CG about 1/3rd of the forward of the transom. Yours appears to further back than that. What do you mean by “foils”? If you mean rudders, making them larger will improve control.
