Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
motor mount
RC Airboats Discuss R/C Airboats here!
motor mount
Old 08-30-2007, 04:17 PM
jesupslanding
Default motor mount
is there a motor mount for a OS MAX FP 40
Old 08-30-2007, 05:03 PM
vamp131
vamp131's Avatar
Default RE: motor mount
you will have to make one put in more info like pics of your hull etc
Old 08-30-2007, 05:57 PM
pinky_d_brain
This may work if you want to by one depending on prop size we normally build them
http://www2.towerhobbies.com/cgi-bin...?&I=LXMNW1&P=7
Old 08-30-2007, 06:21 PM
jesupslanding
thanks but is it only for the airforce airboat
Old 08-31-2007, 07:26 AM
jasperrc
jasperrc's Avatar
There are many options for making your own, it just depends on what you have available. I have a carboard template of the bolt pattern for each of my motors. Then I just trace that on to the motor plate material, cut and drill it out.
I typically make the motor plate from a plastic cutting board. Then use wood or aluminum for the risers. The prefab mounts pinky linked to will also work.
Yes, I know the pic shows a wood prop.[X(] I don't use them anymore.
