Airboat in Fiberglass -My third airboat
Hello ,
Sorry for my English.
I’m working on a new construction of my third airboat.
As I had done two models airboat with plates of fiberglass, the first plan of manufacture according to the hydro-spark.
The second reference used in the first, but changed the half-tunnel, now I am building a new aerobarco based plans tedjones, U7 and thirfwaytoo ...
The way I started to do the same, is a little different than normal.
I started the project, making plates of fiberglass, and then cut, only the ferry bulkhead.
I think it is a work of low cost, but it must have paciencia.
The projects cited above, tried to find a way between the three plans (tedjones, U7 and thirfwaytoo) trying to reconcile the scale and dimensions qem keep looking model that could use a motor .40
In my new project, this hydro should have the following dimensions
Length = 30 "
Width = 15 largest "
Width = 8.5 lesser "
Length = 30 "
RE: My third airboat
Yes ..... it is that.
You have to be very patient to the boats.
The yellow and orange "spark" has been done with cards, fiber and balsa only in bulkhead,the green has been done all of fiber, including bulkhead..
MI
it looks very good. That is a nice fiberglassing job.
By the way, You dont have to apologize for bad english. Everyone does and i dont get why. Most americans dont even attempt to speak another language. So i give you lots of credit for trying
I am taking spanish classes now. I am doing muy mal.
No,
The same is still in the construction phase, as in the first and second boat took very little pictures, I decided to post photos of the progress of construction of this so you can show my ideas and also receive new ideas.
jesupslanding,
I do the leaves of fiber on sheets of aluminum with application of automotive wax to facilitate the withdrawal of sheets of fiber. (See of sixth to eighth photo)
Manufacturing support of the engine.
Based on the size you want in height or size of the propeller, design and cut two pieces of sheet aluminum (left and right), because in aerobarco, we do not have these types of measures, unless the media challenges and start work .
MI
That seems to work great, awesome job, can wait to see it finished. Im working on a boat right now also but it is a catamaran and its not an airboat.
Are you useing polyrithane or epoxy?
