AquaCraft AirForce throttle cable
KY
Has anyone had an issue with the throttle cable not wanting to return the throttle to the idle position? If so, how did you fix it?
David
David
FL
RE: AquaCraft AirForce throttle cable
Is this a new boat? Or has it got some use out of it?
Does it move to full throttle? Or is the travel limited?
Without seeing a pic, I'm just speculating here.
1) There may be binding in the cable somewhere.
2) There may be debris within the cable. Dust, dirt, sand, etc.
KY
Thank you for the reply. It is a brand new boat. It moves to full throttle and has a full range of motion. If you disconnect the cable at each end it seems to slide easily in the tube. Just wonder if it may be a servo issue?
FL
I have the same boat, I finally got to enjoy it. I am having the same problem you are having I tried spraying wd-40 in the cable housing, wish you luck with this boat it is nice if you can get it going good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
let me know if you figure it out and ill do the same for you!
Rich
Saint petersburg, FL
Rich
