Go Back  RCU Forums > RC Boats > RC Airboats
Reload this Page >
alligator airboat mods?
RC Airboats Discuss R/C Airboats here!
Old 12-25-2009, 11:46 PM
Bush_Wacker
Default alligator airboat mods?
should i do anything to it i want to keep it about the same but the strakes keep fliping me
Old 12-26-2009, 01:09 PM
DJLaPalme
Default RE: alligator airboat mods?
Bush Wacker, I modified mine by removing the strakes, cutting the "V" out of the bottom and sanding it to a concave shape, then I widened the hull by two inches each side. It drastically changed this boat around. It will not flip as easy( I have'nt flipped it since the mod) and it will handle rough conditions a whole lot better. I will be doing a "How to" thread with a friend of mine and his boat after the first of the year. It will make the boat a lot more fun to play with. Dennis
Old 12-26-2009, 02:27 PM
Bush_Wacker
thanks i might do that im looking in to makeing one like my real airboat so i will see but thak you
Old 12-26-2009, 02:29 PM
Bush_Wacker
o yea if u cut the strakes and the "V" will it cut into the hull ot is it all fiberglass
Old 12-26-2009, 04:14 PM
DJLaPalme
The hull is a foam shape with a piece of wood down the center and covered with fibreglass. I sanded the strakes off without penetrating into the foam core. I drew lines on the bottom of the hull and cut through to the foam. I gently pried this piece out, epoxied a piece of 1/16th" plywood in the space left, and sanded till I had a smooth concave bottom. Doing this helped some but not enough. The boat still flipped too easily. That is why I widened the hull two inches each side. No more flipping now. Dennis
Old 12-26-2009, 04:44 PM
Bush_Wacker
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
