airboat in progress
I am currently building a airboat and am having a little trouble, i have a 25cc 1.2 hp weedeater motor with a 16x10 3 blade pusher prop mounted on a carbonfiber hull 32x17x2.5 the boat will move ok on the concrete but will not budge on the grass n e ideas
RE: airboat in progress
Davids rc sounds like you are well on your way. There are a lot of skilled airboat builders on this forum that can help you. Do you have pics so we can see what you are working with? You should meet up with DJLaPalme, he lives in your area.
try some wd 40
ORIGINAL: davids rc I am currently building a airboat and am having a little trouble, i have a 25cc 1.2 hp weedeater motor with a 16x10 3 blade pusher prop mounted on a carbonfiber hull 32x17x2.5 the boat will move ok on the concrete but will not budge on the grass n e ideas |
<div class="row"><ul class="tmbnails clearfix"><li class="img">http://thumbp6-ac4.thumb.mail.yahoo....&fid=Inbox0520111606.jpg<li class="img">this is the only pic i have i was just testing i hand throttling it and as i said it was ok on the concrete but not on the grass <br type="_moz"/>[/list]</div>
ORIGINAL: davids rc <div class=''row''><ul class=''tmbnails clearfix''><li class=''img''>[img][/img]0520111606.jpg<li class=''img''>this is the only pic i have i was just testing i hand throttling it and as i said it was ok on the concrete but not on the grass <br type=''_moz''/>[/list]</div> |
if u only have 1.2 hp u have to much prop on there. slick bottom would help u run the hill better. but u have to get some more rpm . maybe bigger carb would help too. i have a 4.25 27cc motor and i run a 14x7 3 blade. my 50cc twin with 5 hp i run the 16x10
so a 13x8 3 blade would be better
yes i would think. how much does your hull weigh?
bout 5 or 6 pounds this is my first airboat
i had a friend cover it in epoxy feed carbon fiber and i think it may be to heavy
it should move on the grass. my boat weighs 29.40 lbs. if you motor is 5 lbs and hull is 5 lbs . it should move. post a better pic when u get a chance. is the boat a flat bottom?
yes it is a flat bottom
i would try other prop. and go from there. if all else fails u can buy a 27cc 3.25 hp cy motor off ebay for 150. that will make that thing fly
i was told that i could cut this prop down if need be is that true
ORIGINAL: davids rc i was told that i could cut this prop down if need be is that true |
You can, but you have to balance it or it will vibrate and wear out your bearings and loosen up your bolts and screws. Dennis
ok well i think im just going to build a new hull and buy a new prop the problem is their is not many pushers to choose from especially in the 3 blade where can i obtain planes for the hull or is it better to just wing it
If you cut the prop down go no further than 1/2" on each blade from the tip.
i have a cut down reshaped and rebalanced 16x10 to a 14x10. if u want to try it,. before i would build a new hull i would get a different engine. thats not alot of power for a heavy motor
that would be great if you do not mind ptr34 how can i get it
maybe coming up that way on the 5 i could bring it and we could me at the pond
David, I live in Port St. John. I have several props you can try. Give me a call and I will do what I can to help you out. I pmed you my #. Dennis
looking to trade my masterairscrew 16x10 3 blade pusher prop for a masterairscrew 13x8 3 blade pusher prop
