As per request
1 Attachment(s)
3-seperate posts of pics.
This one " 1/2A" "Wing Ding" The fisrt four are of the "Beast". An ugly wood hulled w/.48 showing the twin rudder hook-up. Dispite the uglyness, it's a screamer...! __________________________________________________ _______________ The next one, is of a 1/2A under construction. As "Pro27" would say, it's WOF. __________________________________________________ _______________ The next three is the "Wing Ding" also under construction. The hull is 37" x 17" and all 3/16" fiberglassed plywood. Ready to run weight will be close to 10 lbs. The wing is fiberglassed balsa. And can be adjusted in height to accomadate any size prop. I don't know at this time what engine I'll use. I may go with a 25cc ????????? __________________________________________________ ________________ |
| All times are GMT -8. The time now is 12:33 AM. |
