As per request
1 Attachment(s)
1/2 A
RE: As per request
Do tell me more on the wing.
Are you planning to fly off of a boats wake? What motor will you be using and where will it be located? BTW! Very nice job, you should be very proud. |
RE: As per request
[X(][X(][X(][X(][X(][X(][X(][X(][X(][X(][X(][X(][X(][X(]
I think I see where you are going with this. Great idea!! [sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif][sm=thumbup.gif] Please give us the details!! Will you be bringing that with you when you come down to Florida? |
RE: As per request
nice grass[:-]
RE: As per request
nice grass Help me out....I don't get it! [sm=confused.gif] |
RE: As per request
1 Attachment(s)
Wing Consept.
The concept is strictly an "Oh Wow...! approuch. It really dosn't have any aerodynamics, it evolved from just a stright wing to the "Delta" wing. I will probably run a 60 size engine, or maybe a 25cc srting trimmer motor. Don't know yet. Like I said in the first post, it will weight close to 10 pounds depending on the motor I choose. If you expand the first pic, and look on the deck right under the wing, you will see (4) holes. From the bottom side of the deck, I expoxied a "Drilled and tapped" aluminum plate to except an aluminum motor mount that is in the process if being machined. I only took an educated guess as to where the CG will be. There again, it will depend on the motor I choose to use, and the design of the motor mount will allow me to adjust that. Attached is a pic of the wing section before it was covered. (Mock-up) It dosn't show, but I added two wood spars (3/16" dowels) that go through the sections. And by the way Chris, I will have it in Florida...! Also I hope to have the 1/2A ready as well. |
RE: As per request
That's great!!! I hope the boat performs like you invisioned!!!!!
I can't wait till October!!!!! |
RE: As per request
daddyro
In the pic above sirwalter has a very nice lawn. |
RE: As per request
sirwalter........
you say the 1/2A hull is a WOF ? Great job. How long you been doing this?????;):D What are the dimensions? length... beam... rise...at transom bottom center to deck angle used on the hull bottom (v) ???what make of prop is that? I've never seen one for a 1/2A with that much blade area. That thing should provide LOTS of thrust [8D] |
RE: As per request
ORIGINAL: dadaddyro nice grass Help me out....I don't get it! [sm=confused.gif] LOL...... dadaddyro.........not all of us have a big lake for a lawn :D Time to go pull the dandylions........(wish I had a lake for a lawn) lol |
RE: As per request
Interesting idea on the wing.......
Maybe down the line you can make the wing take off from the hull on its own to be a glider:D With radio gear aboard, of course... |
| All times are GMT -8. The time now is 11:11 PM. |
