rudder
Hi,
For an airboat, do you call the rudder a rudder or what?? I need one for mine that im building if anyone can point me towards a rudder assembly. thanks alot. |
RE: rudder
Yes we call them rudders. For an airboat you can use an air rudder or water rudder.
If you want an air rudder, you'll have to make one yourself. I'm not sure if a water rudder off of an outrigger or tunnel hull designed boat will work. I'm assuming it would....since I have no experience with them. Good luck with your build! |
RE: rudder
If you do a SEARCH in this forum on 'rudder' you should come to some posts that show several of my rudder set-ups that were posted a while back. Also pics and a little description of them.
