RCU Forums
-   RC Airboats (https://www.rcuniverse.com/forum/rc-airboats-246/)
-   -   plexiglass????? (https://www.rcuniverse.com/forum/rc-airboats-246/5586935-plexiglass.html)
chrono_war02 03-19-2007 07:52 PM
plexiglass?????
1 Attachment(s)
hey
i have recently built a airboat but my engine mountings are made from 5 milimeter plexiglass that us bent at 90 degrees and is joint directly onto the boat the plexiglass also holds fuel tank and servos the engine is a thunder tiger GP 25 will the plexiglass hold it or will it shatter, and what if i soft mounted the engine on ruber or neoprene????
PS ignore the block thing under the mounting its a desighn error
thanks
crispyspa 03-20-2007 01:31 AM
RE: plexiglass?????
Plexiglass might not be tough enough. If you want the clear look you could use Polycarbonate sheet, it's tougher than plexi.
chrono_war02 03-20-2007 07:55 AM
RE: plexiglass?????
now the actual material that i used is acrylic i am not sure can anyone give views on this
chrono_war02 03-20-2007 07:57 AM
RE: plexiglass?????
for get the last post plexiglass and acrylic is the same thing
Mr Cajun Gator 03-20-2007 08:01 AM
RE: plexiglass?????
I have tried acrylic sheeting on rudders for a .25 hull, did not work, for very long, with in a week it was cracking. Using this on a engine stand will not be a good idea. The engine stand is one of the most important parts of a build.
asmithnc 03-20-2007 01:12 PM
RE: plexiglass?????
Be very careful with this plastic. When introduced with Methonal in your fuel it will crack and cause failures. You can sub it with a clear pvc. PVC hold up much better in a chemical enviroment.
