RC Boats General Discussion Discuss general rc boating topics here.
water pump
Old 10-08-2010, 09:26 PM
Default water pump
Im look for a small elec water pump that I can run to cool me motor I would like something that I can run off my receiver batt but if not its cool
Old 10-09-2010, 08:37 AM
My Feedback: (51)
Tidnab's Avatar
Default RE: water pump
You don't want to draw power from your receiver battery.You would want a seperate 6 volt battery for a small 6volt pump.You don't really need a water pump if your engine doesn't have a clutch.The forward movement of the boat supplies enough cooling water from the pickup.I bought a boat that had a nitro engine in it that someone setup an electric pump to only operate at idle or at very low speed and was not on all the time.It had the throttle servo arm touch a switch that turned the pump on and off and was also setup as a bilge pump when the pump was on .
Old 10-11-2010, 04:11 PM
ya but here can i get a 6.0 v pump
Old 10-11-2010, 05:41 PM
Hydro Junkie's Avatar
As he said, you don't need one in your electric boat. The only exceptions would be if you have major water leakage problems, use a fire monitor on a scale boat or run a combat ship
Old 10-11-2010, 06:15 PM
My Feedback: (51)
Tidnab's Avatar
I think the pump in the boat is a 12 volt winshield washer pump operated on 6 volts.Just enough pressure to keep the water flowing when needed.
Old 10-11-2010, 06:17 PM
rye
My Feedback: (10)
maybe this will help i use them in my boats run them off a 9 volt battery as soon as i see the lite on i bing her in kept in mine my boats are all gaint size 4"and above last time i had a 5' pt boat out lite came on a cooling hose let lose and fill the boat half way pump was working but not as fast as it was coming in but if i didnt have this and seen the lite on i may have lost her , rye
http://www3.towerhobbies.com/cgi-bin...?&I=LXDZ48&P=7
Old 10-11-2010, 06:19 PM
rye
My Feedback: (10)
sorry i put the above in the wrong fourm []
Old 10-18-2010, 02:55 PM
Tachikaze's Avatar
Depending on the size you want.
[link]http://cgi.ebay.com/DC-6V-Mini-Submersible-Water-Pump-35-GPH-P-32A-/260677356737?pt=LH_DefaultDomain_0&hash=item3cb194 ccc1[/link]
Old 10-20-2010, 10:44 AM
Rich404's Avatar
Hi Superflyboy,
Why not just run a 1/8" tube through the hull facing the prop and have water tubing run to your motor and out the boat? This way, your propprovides the water pressure as you accelerate rather thancontantly runa dedicated pump that will take away from your runtime and add more weight.
-Rich.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
