RC Boats General Discussion Discuss general rc boating topics here.
first speedboat
Old 10-21-2010, 02:58 PM
Default first speedboat
<span style="font-size: small"><span style="font-family: Comic Sans MS">hi everyone,
i am a newbie and i got my 1st speedboat 30kph its a joysway offshore warrior lite
i took her for a test run today she seems to go straight'ish until the power kicks in and she get a bit of lift then shes wants to go left. i think its because the battery is mounted on the left hand side of the boat and once shes out of the water she wants to list to the left.
if im right, the question is should i beputting right rudder into keep her straight and risk loosing efficiency in a right hand turn. or should i be putting some weight on the right hand side and risk loosing power.
or am i thinking down the wrong line, should i be doing something else. im used to flying rc planes, and i have just started with boats.
so any advice is great. thanks all.
Tony
</span></span>
Old 10-21-2010, 03:10 PM
Hydro Junkie's Avatar
Default RE: first speedboat
Time to get into specifics. Here is some things to look at and check out:
1) which way does the prop spin looking at the boat's transom?
2) what is the prop made out of, plastic, berillium copper or stainless steel?
3) is the prop sharpened and balanced?
4) which side is the rudder on?
5) do you have any pictures you can show us
These questions will help us in diagnosing your problem as there could be a couple of things causing it. Somehow I don't think battery location alone is causing your problem and countersteering just scrubs speed. Seeing pictures might show us soomething wrong that you may not have thought about
Old 10-21-2010, 03:29 PM
Dan S's Avatar
HJ,
prop is plastic and the rudder is on the right.
he may have to give it some right trim, he may be able to the some adjustment on the turn fins.
here is a pic and the link.
http://www.storacingproducts.com/joy...tml?cs_cookies[cart_languageC]=EN&cs_cookies[secondary_currencyC]=gbp&cs_cookies[stat_uniq_code]=958827&cs_cookies[csid]=4f98bde1868f9f6d1701d2e4bae40a20
Dan.
Old 10-22-2010, 12:44 AM
thanks guy. just off to work but when i get home at dinner i will have a look at the boat and take some pics.
quite alot to look at, wow time to do some homework and reading.
Old 10-22-2010, 01:00 PM
Hi HJ,
Ihave included a pic. The prop rotates anti clockwise.
The rudder and prop is plastic and the rudder is on the right hand side.
Old 10-22-2010, 01:37 PM
I was thinking it might be a propwalk issue and a thicker unsharpened prop. That just went out the window with the picture of the prop. Looks to be a carbon fiber and not plastic, though I could be wrong
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
