Go Back  RCU Forums > RC Boats > RC Boats General Discussion
 Newbie in boats need advise >
RC Boats General Discussion Discuss general rc boating topics here.
Old 10-24-2010, 09:22 AM
Default Newbie in boats need advise
<font face="Helv" size="2"><font face="Helv" size="2"><p dir="ltr">Hello everyone!!!
I will be free to ask you for some help!?
I am here to look for a little bit of guidance and info.I have been thinking about building my own RC Elec.Pow. BOAT ( pulling fishing line with the bait)!?So i do not need speed,only the power for pulI.So here is what I am interested in:
1.CELL COUNT
2.MOTOR
3.ESC
4.PROP<p dir="ltr">I am looking for the economical way.I am ok with spending money on this but not looking to invest for the top of the line.
The size of boat is between 28"-32" -catamaran?
I have wish to make, not to buy done Ready To Run boat.
Thank you in advance!!!
Regards!!!
</p></p></font></font>
Old 10-24-2010, 10:26 AM
Default RE: Newbie in boats need advise
YOU CAN BUY MOTOR,CONTROL SPEED,FROM= WWW.TOWER HOBBIES=
ID:	1521976   Click image for larger version
Old 10-24-2010, 04:04 PM
For that kind of job you will need plenty of power delivered through a relatively large prop.  <div>The normal rule is to have a prop with a smaller diameter than the motor case,so its either a large motor, or a motor with a gearbox.  If you can find a window motor from a car, or a fan motor, these are ideal, and intended to run on 12 volts (SLA type ideal for displacement boat, NiMH packs if you need to distribute the weight).  </div><div>A 50-60mm 3 blade prop will do the job of putting the power into the water.  </div><div>Almost any low-end simple marine ESC for brushed motors with reverse (most of them) will do the job, as very few are rated for less than 10A, and the car motors are fused at less than that.</div><div>Do you intend using it in salt water or fresh water?  Calm lakes are not much of a problem, but small waves near the shore can be very big for a small boat.  Beach wavelets are very deceptive.  If its for use in a river, the boat needs to be able to go a lot faster than the water flow.  A friend launched his boat into what he considered a slow river, and caught up with the boat about 2 miles downstream.</div>
Old 10-25-2010, 01:29 AM
I will use in fresh water-lake!
Any sugest on type of body?Is it Catamaran a good choice?
Thanks!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
