Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
turborix 2.4 tx will not set with forward only esc, pls help!
RC Boats General Discussion Discuss general rc boating topics here.
Old 12-14-2010, 04:53 PM
pmdevlin
Default turborix 2.4 tx will not set with forward only esc, pls help!
Can anybody please help with this, I have a cheap 2.4 (turborix/flysky) which has been great with my boats that have a reverse esc. I now have a problem, I want to use the tx with a forward only brushed setup boat. This tx is programmable on the pc, so I have eliminated the throttle reverse endpond (its self centre stick), but it will not set, it only sets if I reintroduce the reverse endpoint, put the throttle stick all the way down, it sets, but then if I let go of the stick, it self centres and the motor sets off. There must be a way of sorting this, I cannot do away with self cemntr stick as all the other boats have a reverse esc,
thanks[]
Old 12-15-2010, 09:37 AM
pompebled
Default RE: turborix 2.4 tx will not set with forward only esc, pls help!
Hi PM,
Did you consider a ratchet for that stick?
I have one on my transmitter and use it for speedboats (forward only) and scale boats with reverse alike.
Finding the center/zero point can be a bit fiddly, but it works for me...
Regards, Jan.
Old 12-15-2010, 03:00 PM
pmdevlin
Hi Jan,
yes, it had a ratchet to start with, what I want really is a self centre stick, which I have done, no reverse (the esc is forward only), but it wont set at mid stick, even with the reverse function disabled
Old 12-16-2010, 01:26 PM
pompebled
Hi PM,
If the ESC in question, or the TX at hand, gives you so much 'trouble', why not get another cheap tx/rx set from HC for this boat (and other boats that don't need a selfcentering stick, like a sailboat)?
I've used this one on a speedboat:
http://www.hobbycity.com/hobbycity/s...idProduct=8338
One antenna parallel under the deck, the second one vertical in a short straw, works like a charm...
Only when running in a straight line away from the transmitter, the spray sometimes interfered with the reception, but generally no problems.
Regards, Jan.
Old 12-17-2010, 04:47 PM
pmdevlin
Hi Jan, thats the exact transmitter I bought!
So, as you are familiar with it, its only going to be used for forward only boats, but, as I am familiar with a self centre stick with my other boats, I wanted it again, just for familiarity reasons
I did the self centre mod by moving the spring and getting rid of the ratchet. It looks like I will have to go back to stock, but wanted a failsafe of a sprung throttle stick to go back to neutral, in the event the stick is knocked and the boat goes motoring off, or starts up on a bench etc. I thought it would have been an easy job, but apparently isnt.
I had a look at this, maybe it will solve the problem?
http://www.sgr.info/usbradio/default.htm
thanks
Paul
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
