Newbie - Needs help Please!
Hi
Iwas recently given a old bait boat as a present. Ihave read up on numerous websites and forums as to the various motor's, esc's battery packs etc. however the number of diffrent options, specifications etc. has not made finding a solution easy.
The boat requires a new motors, does not have a esc or a battery pack.Servo's and receiver is still working fine.
Can anyone please assist me in making a recomendation as to the most suitable motor, esc and battery pack for my setup (the prop looks a bit small). It is a bait boat, so I do not need thepower of a speed boat, however it would be nice to be able to play around with the boat when not used as a bait boat. As a newby, Ihave no idea as to what will be suitable for this boat.
Ihave read about waterproof units and watercooled units. Are the watercooled units worht the extra buck if used in a bait boat?
The boat weighs 4.9kg's and is92cm long and 37cm wide at the widest point.
Your advise will be highly appreciated as I have no idea what motor and esc to invest in. From reading various posts, choosign the incorrect equipemnt will result in numerous problems e.g. overheating, power loss etc.
I include a few pics.
Carel
http://www.proboatmodels.com/Product...ProdID=PRB2314 Speed Control
http://www.proboatmodels.com/Product...ProdID=PRB3105 Motor
http://www.duratrax.com/batteries/dtxc2145.html Battery
Hi
Thanks for the info. I have checked out the links and the equipment looks great.
You mentioned the 550 motor will power the boat. Forgive me for asking, (this is purely because I do not know any better) would it be worth spending a few bucks more and getting a larger motor e.g. 750. (I noted the 750 motors when checking out 550 motors).
Would this be overkill or money well spent?
Thanks for the advise. It is highly appreciated.
Carel<o></o>
