prop needed
prop needed
I have this old boat (been told its an eco, if that means anything) and a couple weeks ago the prop broke.
I took a stab in the dark and bought a prop for the traxxas blast. I got lucky and it bolted on!
Problem is, its a thin peice o crap and chipped already (1st time out)
Id like a metal prop, but didnt see any on ebay that screw on.
Id also kinda like one that has alittle more pitch than the traxxas prop. but I wasnt able to find specs on the blast's prop.
So I need a screw on prop, like the one pictured. anyone got any ideas?
RE: prop needed
For a correct answer , we need to know :
What's the diameter (from blade-tip to blade-tip) of the prop ?
And what is the threads in the prop ? Metric (M4 or M5) or Imperial?
RE: prop needed
Eco i believe is a brand>>> https://astecmodels.co.uk/catalog/index.php?cPath=2_88Hendric is right take some pics and measurements. and to be honest ive never seen a metal prop that is threaded but if your prop stub is threaded and long enough you may be able to add a drive dog+regular prop+prop nut if you know the threading or buy couple different threading/sizes to figure out which fits.
http://www.offshoreelectrics.com/pro...prod=ose-80005
http://www.offshoreelectrics.com/pro...aded+rtr+props
http://www.offshoreelectrics.com/pro...?prod=ose-8135
A different size of drive dog, prop inner diameter or adapter such as 1/8 to 3/16 fitting for a 1/8 shaft and 3/16 in. prop and the prop locking nut with the same size/threading as your shaft. If your handy enough with tools or just know how you may be able to thread the side of a metal prop and still attach a prop nut for extra precaution of it coming loose with out a drive dog but its your boat and my suggestion keep us updated i see that boat is small you could make it a little power house check this out>>>
http://www.rcgroups.com/forums/showthread.php?t=1319724
RE: prop needed
hi i have acouple of props that screw on and that also look just like that but then again it is very hard to tell..if it would help you i would just give you one to try..i needed help once and a person just gave me the parts lucky they worked..if you would like to try.my email is [email protected] my name is rick..who knows it just might work...TAKE CARE....
