Go Back  RCU Forums > RC Boats > RC Boats General Discussion
 Help with boat hull manufactory >
RC Boats General Discussion Discuss general rc boating topics here.
Old 09-05-2012, 09:35 AM
Default Help with boat hull manufactory
Hello-
I need help to identify who manufactures a boat hull that I am looking into buying.
It is a Catamaran hull that is 50” long.
Also what is the size limit for the engine (Gas or Nitro)?
Thanks for any help
Jwelch5792
ID:	1798654   Click image for larger version
Old 09-05-2012, 12:39 PM
Justaddwata's Avatar
Default RE: Help with boat hull manufactory
Believe it is the Popeyes 50 by Aeromarine. The hatch of the 50 has a pair of scoops but I believe it used to have the 4 detents like the one you show (and same as the Popeye's 42") http://www.aeromarinerc.com/index.ph...=142&Itemid=53
Would work well with a 26cc Zen, Sikk, RCMK, etc. I believe the top of the motor will be exposed through the hatch as there is not a lot of clearance - not a big deal. Also will likely have the pipe cut through the back of the hull.
If you want to fully conceal the motor and pipe you might look at the Aeromarine Conquest or avenger Pro (http://www.aeromarinerc.com/index.ph...d=37&Itemid=53) or Express Craft Thunderbolt http://expresscraft.com/thunderbolt.html which will hold the same motor concealed.
Old 09-06-2012, 04:58 AM
Justaddwata-
Thanks for the info.
It was very helpful.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
