Go Back  RCU Forums > RC Boats > RC Boats General Discussion
Reload this Page >
HK Quanum Aquaholic rc boat flex shaft
RC Boats General Discussion Discuss general rc boating topics here.
Old 04-28-2014, 03:04 AM
rhardy60
rhardy60's Avatar
Default HK Quanum Aquaholic rc boat flex shaft
I've a HK Quanum Aquaholic rc boat and I've gone threw 2 flex drives , I'm running 3&4s batteries , the problem is the end that goes into Coupler comes unraveled , any idea's how to solve this ? I've tried soldering the one end but can't get the solder to stick even after cleaning it .Hears some pictures of what happening .
Old 04-29-2014, 05:37 AM
rhardy60
rhardy60's Avatar
20+ people had looked and no one has any ideas how to solve this problem , go figure .
Old 04-30-2014, 04:40 AM
w3bby
Pics are useless, try new ones that are focused....
What type of coupler is it? If it uses grub screws then change it out for a collet, grub screws damage the flex shaft.
If you can't get solder to stick then the a. the parts aren't clean or b. you have your temperature wrong.
Old 05-01-2014, 08:49 AM
rhardy60
rhardy60's Avatar
If's you can't get solder to stick then the a. the parts aren't clean or b. you have your temperature wrong.
It got the hex set screws but i'm going to change it to this http://www.offshoreelectrics.com/pro...prod=ose-81505 this is the right size but a little longer , i also have a friend making me 5 spacers out of 1/16" flat aluminium stock witch should give me more room for new coupler , the motor shaft is 5mm and the flex drive is 3mm
Old 05-05-2014, 05:01 PM
rhardy60
rhardy60's Avatar
Update , Put in the new coupler with spacers , looks good to me , now have to wait for new flex shafts to come in . hears some pictures of what i did so far .
Old 07-14-2014, 10:44 AM
rhardy60
rhardy60's Avatar
Update thing are going GREAT with this setup have about 25 runs on it this yr and had no more problems with flex shaft . where last yr i went through 2 shafts by now after this many runs and it take me about 12 min, to grease flex shaft from start to finish .
