UL-1 Silly Question
UL-1 Silly Question
I have a UL-1 that is pretty much stock. It's plenty fast enough; however, I am just unsatisfied with the lack of ability to turn (effectively) both directions. I figured, maybe I could pull out the hardware and put it into something else. www.hobbyking.com has lots of hulls, so that would be a start. I use the same batteries in my Traxxas Rally that the power the boat, so that isn't a problem either.
Just looking for ideas.
Crusty.
Crusty.
There probably is as the driveline by itself is getting very popular with the racers so classes have been formed using it. www.offshoreelectrics.com has hulls for just about everything electric. I shouldn't mention it but they've also got a good forum area for FE boaters. You can later unload what you don't use from your donor.
