RC Boats General Discussion Discuss general rc boating topics here.
Nqd jet prop
Old 11-13-2014, 08:12 AM
l8rg8r
l8rg8r's Avatar
Default Nqd jet prop
Ok I've had this nqd jet I've changed the prop and main shaft now I can't get the prop to stay in place when I give it full throttle the shaft spins in the prop how do you guys fix this on yours
Old 12-15-2014, 02:36 PM
the lone rcer
the splines on the impeller shaft have stripped out the plastic . you could try and move the impeller back or forth to get the splines to bite fresh plastic in the impeller. or try and crazy glue the impeller onto the shaft. if none of that works i might need a new impeller. hope that helps ya out.
