Shark Fin
Shark Fin
I'm building a shark fin with twin motor / propellers. I'm not looking for speed and would rather steer by variable speed to the motors than a rudder. I haven't rigged this before and am not sure how the electronics work. I'm using a Flysky FS-GT3B controller. I have 2 speed controllers. Without a rudder I can use a servo to rotate the motors up and down for a variable depth of the fin in the water. I don't plan to submerge it but just a bit of up and down will be great. Any Help? Thanks
We don’t have near enough information to help you. What size fin, dogfish or great white? What motors and ESCs? What voltage? What speed do you want? Where will the motors be placed, if placed in the rear the fin won’t submerge well by just rotating them up.
I should also mention, as a disclaimer, I live in Colorado, far from salt water where this would NOT be a funny joke.
Oh and also I have a 1060 60A waterproof ESC
Think of a sailboat setup, with out the boat part showing.
some PVC pipes make it in to a "t", rubber end cap for easy replacement of battery.
motors at the bottom of the keel (motor can run underwater just wd40 after each run), 3 to 4 inches apart. For steering.
if you are using 2.4GHz, put the receiver as high as you can on the top of the "t".
Others then fin you could put in a alligator head too.
added: this should help
https://www.rcgroups.com/forums/showthread.php?1537093-Empire-State-Model-Mariners/page696#post35702957
