Rc boat cuts out at high load
RC Cuts out during High load
Hey I need help with my RC boat I would appreciate all help I can get.
Last summer my boat started behaving strange it started cutting out when I hit around 70% throttle but when the propeller was out of the water (not under load) it did not cut out and I could run it at full throttle (didn’t run it a long time because it’s water cooled) it runs off 2x 7.4V 4000mAh 35C LiPo batteries. It seems it can’t handle load for some reason. After it cuts out i have to drop the throttle to 0% and then i can accelerate again.
Boat- joysway bullet V3 (stock)
Batteries 2x - 7.4V 4000mAh 35C LiPo (included)
Charger- intelligent lithium 2s/3s balance charger J-BC3S01 (included)
Appreciate all helpful answers
And now is where the fun starts.
I can think of three things that would do that:
- Too much power for the ESC to handle so it's "thermalling"
- Too much drag in the system. Have you greased the drive shaft or strut?
- Too much prop
- Too much prop
I don’t know what u mean with the third one ?
Okay, you just filled in a few blanks for us.
I took my scale boat out yesterday, first time in a year(gee sound familiar?) and, first thing I did was grease the drive shaft. Last time prior, that being last summer, I hadn't greased it and it let me know very quickly. My drive shaft runs inside a brass tube and the metal-to-metal contact had it literally screaming. A quick remove/grease/reinstall took care it that issue and it was actually running decently, that is until the boat in front of me died and I had no time to react. The resulting collision took my boat out for the rest of the day and, by the time I got it fixed(work schedule killed a lot of time so the repairs took several weeks), I was forced to call it a season.
- The drive shaft needs to be greased either before or after a day of running. This is especially important to grease the shaft BEFORE RUNNING if the boat hasn't been run in a long time. Grease left for long periods can and will get hard and increase the load on the motor and ESC
- If the battery connector melted, that means it was either not installed correctly, causing serious resistance(resistance = heat) or your motor was drawing too much power, possibly due to drag from the drive shaft.
il try greasing the prop shaft again
What most don't think about, and I should have mentioned, is that the load put on the motor/ESC/battery pack, when the boat is on the stand, is only a fraction of what it has when the boat is running in the water. Since the boat runs fine until you get up toward full power, that pretty much leaves loading as the only variable. Now with that said, one other thing that "could" be happening is that the drive shaft is pushing against the motor and causing it to have more drag. I doubt that is what's going on in this case but, then again, you never know when it comes to boats
