Starting an inboard engine
I am a novice R/C Boater and unmasking the mysteries of how to find running hardware and the components of an inboard engine are still a mystery to me. But the main mystery is how do you start an inboard nitro engine that doesn't have the pullstart option?? Please advise.
Devan
[email protected]
Devan
[email protected]
So why wouldn't you just buy a pull start engine to begin with?? I mean you would need a 12 volt battery and an engine starter just to start the engine. Or you could just pull on a pull start and not have the odd angles and issues with placing the boat somewherer, holding the boat, holding the starter and sometimes holding your finder over the engine throttle to get it to start.
My Feedback: (21)
First ... not all engines HAVE the option of pullstarters .
Second , it NOT a very wise thing to do HOLDING your bat while starting it . LOTS of things COULD happen .
Lets say ... that nice copper prop decides it wants to "taste" how good your leg might be ? Because you "accidently" moved just a bit the wrong way ?
Or ....
How about the poor ole hull itself ? Hummmm ... all the UNEVEN pressure caused from the person holding it and then appling the starter ( whether its a pull start , or electric start )
So , lets see .... how about ease ???? Put the boat on a boat stand ... THEN you will have your BOTH hands free till you get ready to start the engine ...
So , we have a safety factor , and a reason for longevity of the integral part of the hull for two main GOOD reasons why NOT to start the boat whilst holding it .[8D]
Issues ???? wouln't have them if you put the boat on a secure boat stand
Or ....
I've got a pull started OS .32 and would certainly be happy with an electric start on it. Fuel gets in and fouls the cord, the spring can uncoil, rust and/or break, pulling it while not firmly holding the engine can jerk the motor or boat around and this can mess with the mounting system. I could probably have bought an electric starter and belt for the amount I have paid in replacing the pull starter 2 or 3 times
