Need Help with my Atlantio's Cooling Coil
CA
Hello....I guess I need some help with the Atlantio again...I never got around to installing the cooling coil, so I am thinking about doing it today....but as I looked over it last night I found some problems....my rudder/propeller is not out of the water, and all of the directions I have gotten are for boats like that...where to I drill my water pickup....(I know where to put the outlet) I was thinking about putting it at the front under the water so when you go forward it pushes water in...What does everyone think?
PA
Fasten it to the transom, and make a slight bevel on the end of the tubing to face the bow of the boat, just slightly below the hull.
