RC Boats General Discussion Discuss general rc boating topics here.
Live Steam
Old 10-28-2004, 11:57 AM
tdonily
Default Live Steam
Hey everybody,
I'm looking into starting into live steam. Has anyone here worked with any of the companies out there that produce steam plants? I had thought of starting with a Midwest Heritage engine/boiler in one of their boats made for it. But I would like to have more control over the boat other than steering. And I know that Cheddar and Wilesco make engines that can be reversed. Thanks for any help you can offer.
Old 10-29-2004, 07:30 PM
gulfstreamI
Default RE: Live Steam
ORIGINAL: tdonily
Hey everybody,
Hello tdonily,
I've got a steam powered boat project by Midwest Products Co. Inc. I've had the same thought of including a servo to control a gearbox that should shift the prop into reverse. I'll have to do a little more research on Cheddar & Wilseco on how they did it. I'm also thinking of getting an extended runtine on the sterno fuel. What I'm worried about is an exploding boiler.
GulfstreamI
Old 10-31-2004, 11:46 AM
tdonily
What's your runtime with the standard Sterno can? Wilesco and Cheddar reverse their engines by re-routing the steam into the cylinders. So it's valve work vs. a gearbox. The engines still drive the prop shaft directly.
Old 11-03-2004, 07:22 PM
gulfstreamI
The runtime on the sterno can is 6-7 minutes. I've tried extending the runtime to 10 minutes by preheating the boiler before I launch the boat in the water. The only problem I see is a gust of wind that might snuff out the flame in the firebox. The valve switching system is a good solution to shift the boat's prop into reverse. Here's a few pics of the boiler running. This steam engine makes a nice putt-putt-putt sound. The flywheel spins very fast at peak pressure.
GulfstreamI
ID:	189604   Click image for larger version
