Need info on k&b 7.5
NC
Could someone please post a closeup picture of the correct plumbing for the cooling of the k&b 7.5 outboard. I have a new one with now paperwork. Two fittings on teh head- 1 same size on side of lower unit and 1 larger fitting on the oppisite side of lower unit. Help me out please. Thanks in advance, BAD ANDY
AB, CANADA
Hi, if it's the same as a 3.5, the line attachs to the tube inside the leg, out to the head and out the other side. Hope this helps, you'll have to forgive my crappy camera!! Dirt
NC
Close but not the same
Thanks Dirtman, the engines are close but on the 7.5 there is another nipple under the one that the head goes to. It is positioned 3/4" lower and 3/4" forward. Thanks again, BAD ANDY
TN
Go to K&B's website and you can get a full blow up of parts for the K&B 7.5cc outboard engine. I've got one on a tunnel hull and man does it rip the water. K&B's site is modelengines.com. Hope this might help
NC
I can make you a picture of my correct installation. I have a near vintage configuration run once sitting on a dumas 7.5 hotshot.
It is a screamer that needs heavy front end ballast to keep from becoming ballistic. Still need info let me know. I will look for a picture, post it on one of my website pages when you reply. I have many construction photos taken also and may give different views of my installation.
