Newbie traxxas blast question.....
I could really use some suggestions on my new boat, everything seems to work fine untill the boat reaches top speed. It seems to do a whole lot of hopping. I've tried several different adjustments on the prop but nothing seems to help. Any suggestion on how I should set it up in order to get the best performance out of it. Thanks for any help.
OH
RE: Newbie traxxas blast question.....
well first do yo have any up grades? like bigger motor or anything that is put in there to make it go faster?
One problem could be that your prop is too high above the water. did you try to ajust the trim angle to a lower position? Another thing that you could do is put more weight in the front.
