Questions about Miss Bud 1/12
I have 3 questions about the Miss Bud 1/12. First, what are you doing to seal the radio box. I have tried everything and still get water in there. It is coming in around where the lid fits on, not the control arms. Second, what kind of grease is suggested for the prop shaft. Third, what if anything has anyone done to make it turn a little sharper. I know sharp turns make it more flipable, but I cant get it even close to scarry most of the time. Am using almost all of the rudder travel.
For those who do not know, the Y535 prop is a lot better than the Y 534 that comes on it. It will get on plane on its own with the 535. If you mess up and get it off plane, it will get going on its own.
WA
To answer your first question the water is coming in under the switch, and to fix that I would put in a water proof switch. Now to answer the second question I use Prather cable grease. Now to the third question on the side of the transmitter there is a thing that you can slide back and fourth to make it steer faster. I hope I was able to help you and good luck.
Scott
Scott
WA
Check the thread lower down titled Speed nitro boats.
There are a few of us w/ the same problems and have made the nessesary mods to fix most of them.
Check out our ideas and pics.. http://community.webshots.com/user/Teamchrome
Boataddict has a great piece on the miss bud..
