sanding fiberglass
MI
hey guys! well i have finished fiberglassing my boat. and i am at the sanding stage. my question is what sand paper should i start out with?? and what should i finish with?? i have laid down cloth and 4 coats of resin over that. so now my question is what grit sand paper should i start sanding with and what is usually a good finishing grit. I have a dumas chris craft, and i need YOUR help!
P.S how do i know when sanding, when it is time to switch to the next finer grit??? I NEED TONES OF SANDING TIPS!
THANKS GUYS!
THANKS GUYS!
Start as rough as you you need to, to get rid of the speed bumps, and crack the any airbubbles.
Once you get it down to a fairly consistent level, go to the next 100, or 150 grit to clean up the really rough spots. At this point I might consider another coat of resin. Then starting out at 150 I would work my way to 220 or even 300 grit, then spray for primer to look for low spots, or any spots that may have missed.
Then I would probably work the hull with 220 or 300, prime again, then consider a wet sand with 300 before first paint.
If you sand with 220, and spray a light coat of prime, and see horrible rough sanding marks back up one grit, and work the rough spot and feather out the scratches to a nice even consisntency and back to 220 grit.
