Pinions & prop rotation
FL
I need a suggestion on a good pinion gear for the villian ex, I have 2 -15 turn havok's super rooster, metal props and so on with stock gears , I'm not looking for off the line speed, I want a higher top end..also what is the true differance if the props are turning inward or outward? the villian with the 15's are turning inward, It doese have trim tabs and runs great- but I noticed the stock one I also own are turning outward, wich is better??[8D]
