electric boat advice needed
KY
I have been into glo fuel rc planes for many years, but have recently gotten into electric boats. I am currently putting together an old mrp miss budweiser kit. the mrp boat has very limited space for the radio gear. Two servos, receiver, and battery pack are not going to fit in the supplied radio box. It did not come with a manual speed control, so i thought i would invest in an electronic speed control. The kit came with a couple of old "green machine " motors.
Is there a speed control in existance that can handle two 6 cell packs in paralell, and use very little space?
Could the packs be wired in series? (would this make the boat faster??)
I could Use any advice on a suggested setup for this dual motor, dual battery pack boat.
Thanks!
Thanks!
My Feedback: (21)
Not very knowledgable on electrics , but what I do know is that its not so important ( within reason , of course ) how much voltage you apply , but rather how many R's the engine can turn with as little voltage ( not amperage ) as possible . ( now , is when the more volatge comes in . Pending on how much the ESC can handle AND , how much the motor can also )
And before buying an ESC , make sure you want to run brushed motors rather than non-brushed ones .
My Feedback: (12)
SC
ORIGINAL: greggtek
If you've already got the motors and battery packs, the most economical way to go would be to get an inexpensive ESC that can handle the number of cells and load from your setup. If you decide you want to get into fast electrics, start looking at the newer hull choices, brushless motors and ESCs, etc. I'm just at the researching phase now, so I can't make specific recommendations. Here's some of the places I've been researching:
http://www.rumrunnerhobbies.com/
http://www.microhydros.com/
http://www.finedesignrc.com/
http://offshoreelectrics.com/
