Villain EX
TX
I purchased a Villain EX and I’m having problems with the prop alignment. They are not straight
and one is a quarter of an inch out further then the other. I did set the trim but it is almost all the way.
Any ideas on what I may have missed?
ORIGINAL: RcHobby33
Lastly, when you turn off the boat some times the outriggers will swing a few mm's one direction or another but when you power up the transmitter, then the boat, the outriggers should jump to nuetral (or wherever you have the steering trim set).
TX
I will have to work on the picture. if i put a straight edge on the very tip of the props they are
not even one is a quater inch back. they just aren't re square or parellel to each other.
RcHobby33
RcHobby33
