Go Back  RCU Forums > RC Boats > RC Boats General Discussion
 Aeromarine 1/8 scale bud hydroplane >
RC Boats General Discussion Discuss general rc boating topics here.
Old 09-12-2005, 12:31 PM
Default Aeromarine 1/8 scale bud hydroplane
I'm looking at buying a Aeromarine 1/8 Scale bud hydroplane hull. Does any one have any pictures of the hull. I looked on Aeromarines web site and they only have one picture of the hull. If any one could post some pictures of this hul I really would appreciate it.
Thanks!!!!
Old 09-14-2005, 03:13 PM
Default RE: Aeromarine 1/8 scale bud hydroplane
Some body has to own one of these boats????????????????????????
Old 09-14-2005, 03:35 PM
My Feedback: (12)
piper_chuck's Avatar
I've sent an email to an Aeromarine dealer I know who may have one. I'll let you know what he says.
Old 09-15-2005, 08:33 AM
Ron Olson's Avatar
It's not a big seller in the 1/8 scale hydro boating world. The serious racers would either build their own or buy a higher quality/more accurate boat.
http://rcmarinedesigns.20megsfree.com/
Old 09-16-2005, 07:14 PM
Thanks for the info Ron!!!! That is exactly what I wanted to know. I plan on getting into racing. Also thans for the link to the other web site. I plan on buying one of their boats.
Old 09-16-2005, 10:32 PM
Ron Olson's Avatar
I've got one of Phil's hulls, the Sport 40 with the Stealth cowl. The downside is that they are epoxy-glas which translates into a lot of pinholes that need to be filled before painting.
Old 09-17-2005, 01:08 AM
What type of filler do you use to fill the pin holes?
Old 09-17-2005, 08:03 AM
Ron Olson's Avatar
Phil says to use thinned spackling, yes, the kind used to fix cracks in walls. I used some White Squadron putty that I got from the LHS. It's used for plastic models. Some will apply a thin coat to the entire hull then sand it off. A lot of the pinholes are hard to see until you get them filled or put a coat of primer on the hull. On expoxy-glas hulls you have to watch the sanding as you can have more pinholes popping up if you start sanding into the epoxy. Use Scotch-brite pads to sand with when you can.
Old 04-25-2024, 09:22 PM
Thanks!!!!
I have the budweiser hull
Old 04-26-2024, 11:05 AM
Hydro Junkie's Avatar
Not sure if you noticed, you responded to a post from 19 years ago.
Old 04-26-2024, 05:32 PM
Default Bud
Better late than never
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
