Twinstorm 800
Twinstorm 800
Hi everybody!!!
I'm an happy owner of an powerful Kyosho Twinstorm 800.
After many runs I have changed original motors with two Traxxas Titan Marine and original battery packs with two 2400NiCd 8,4V by Sanyo. Wow!!
Now some question:
-It's even better NiCd batteries than NiMh batteries?
-I have changed the original transmission (gears and pinions), always with original spare parts, due to normal use.
After a little run with the two new motors I have melted the 40T plastic gear. Any suggestion? Due to more motors power, is necessary to change pinion and gear with others?
When I have mounted new parts I have noticed that coupling between gear and pinion is a little close, it's possible to record it? I think that it's the problem...
-I read in this forum that is possible to change the cardanic transmission near the propeller with a omocinetic solution. I have tried some universal joint from Graupner and Robbe, but both are too longer... Any suggestion? I see some photos in the forum, what kind of replacement metallic universal joint is used?
-I read that is possible to mount 2 motors type 700sc Super charged to get impressive velocity.... How about motor changing? (pinion, gear, motor support, ecc.).
I'm sorry for my english and too many question...
Thanx in advance.
Now some question:
Thanx in advance.
