Go Back  RCU Forums > RC Boats > RC Boats General Discussion
 Firing up the  Cheddar Pintail Vertical >
RC Boats General Discussion Discuss general rc boating topics here.
Old 08-29-2006, 07:55 AM
Default Firing up the Cheddar Pintail Vertical
Hi
I have the above steam engine mounted on the Krick Anna boat with a Cheddar Butane container mounted. I would like to seek advise on firing up the boiler as the instruction is unclear.
Do i light it via the vertical chimney or at the nozzel where the gas tank is connected to the boiler.
Pls help
Old 08-29-2006, 08:00 AM
green-boat's Avatar
Default RE: Firing up the Cheddar Pintail Vertical
You light it as close to the burner as possible. Lighting it at the stack is not wise unless you want a nice WHOOSH.
Old 08-29-2006, 08:06 AM
Hi there
many thanks for the quick reply, the manual says light at the chimmney, I'm not sure what you mean by stack, but each time I light it via the nozzle, I get a nasty whoosh.
I would be brilliant if you could clarify.
Many thanks in advance, I a newbie in live steam.
Old 08-29-2006, 08:18 AM
green-boat's Avatar
Stack/ chimmney same thing. the terms are interchangable. If the manual says to light it at the chimmney, then go by what it says. Sometimes lighting it by chimmney lets a buildup of gas occur causing the whoosh part. I have always lit my burners at the burner. I lite the lighter and then turn on the gas.
Old 08-29-2006, 08:30 AM
Thanks again, green boat. I will try, still having phobia from the last try. Would the butane container catch fire and cause explosion - my single biggest worry. boy oh boy.
Old 08-29-2006, 10:04 AM
green-boat's Avatar
The hole in the gas orfice in the burner is small enough that even if the gas pressure dropped, the flame would not travel back into the gas line. I could get technical with pressure drops and cooling effects at orfices but no real need to here.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
