walmart gas tanks set up??????
Hi i have just got 2 alluminium drink containers to use in my zenoah powered gas boat, i have seen them used before,but cant find the thread does anyone have a link or have a diagram for the twin tank set up and all that is needed?
Thanx for that , that wasn`t the thread i had seen before , the tanks i have are not as big as the ones shown and i`m only using one engine, i should be able to sort out what i need and set up ok (maybe i had seen a set up on another site) Thanx again Rick
The tanks i have are only 250ml each and £1 each (not sure of the $ exchage rate?)not walmart but the same sort of thing and metalic green, I need small tanks as the boat is only 40" long so it should fly,or crash in a great way (just hope i catch it on film)
I just ordered the nipples from Dave Marles here in the UK so i will get the tanks sorted a long time before the boat is ready, because i have other builds going at the same time
Right i have drawn up a design for the tanks as i could not find that other thread,I had trouble finding this one again , PC`s are not my thing ,
anyway do you think this set up would be ok?
Rick
Rick
After searching for that thread for oh about an hour.....nothing. Went through 30 some pages of threads, only found the twin engine thread as well. I would say though looking at your diagram, that's the correct way. I dont see any other way to do it.
Ok thanx for the response that i wanted to hear, now its just waiting for the bungs,nipples and hoses to arrive and i will put it all together, not sure when the boat will get built,i have too many projects running at the same time ?! but when i start, i will start a thread too
