Salt????
LA
Hello all Im new to boating. Been in cars for like 6+ years. My giirlfriend has a house in navare beach Fl. problem is..... My LHS says to "NEVER RUN A RC BOAT IN SALT WATER!!!" Is this true? Or are only some boats excluded from salt like say electric. Any help would be GREATLY appreciated.
1 Post
i run my nitro and electric in salt water all the time. it says not to but u can. just after every salt water run flush out the system with fresh water to prevent corosion.
My Feedback: (21)
Sometimes , asking someone at a LHS is like going to your BEST BUY , going into the computer section , and asking which computer would be best for you and WHY .
. ( I , myself , LOVE doing this and insulting them "sales clerks" with questions , that they have NO knowledable answers to .... )
You'll need some corrosion block, crc 656 and a flushing setup for the engine. IMHO, just running water through the cooling system isn't enough, I prefer to run the engine and let it get to tep with the fresh water running through it. You can get stuff at the local Home Depot or Lowes. Get a garden hose adapter for an ice maher and some 1/8" hose. Take the pickup hose off at the water picup and using a piece of 1/8" brass tube hook up the fresh water flush and run the engine for 5 - 10 mins on the frsh water. The reason being is this: when you run the boat in salt water, the salt and minerals are in the engine, when you shut the engine off and drain it, the salt and minerals are still in the engine baking themselves to the inside of the engine. By running the engine back up to temp on the garden hose, you will loosen the salt and minerals.
I have to run my boats gas, nitro, and electric in a salt water canal, or spend half a day traveling to a fresh water pond. After use, all i do is give them a good strip down, and clean everything, and then grease and oil all the parts that need it, just as i do on when they get used on the freshwater lakes and ponds. Salt is only a problem if you dont lookafter your boats, but its great on chips/fries
