PLEASE HELP
I HAVE A 1400NI MH BATTERY PACK W/ RED AND BLACK WIRE . I HAVE A AM RADIO AND RECEIVER WHEN I PLUG THE BATTERY IN THE RECEIVER AND THE SERVOS I CANT GET MOVEMENT BUT WHEN I UNPLUG SERVOS AND TEST THE RECEIVER WITH A METER I GET POWER. NOW THE RECIVER HAS ONLY THREE HOLES FOR BATTERY AND ONE FOR CH1 AND CH2. IF I HOOK A SERVO UP TO CHARGER I GET MOVEMENT. CAN SOMEONE PLZ HELP ME I BEEN WORKING ON THIS FOR 1 WEEK???????????????????????
WA
look at the charger red/black? then matchup the battery pack to the charger and see if the colors matchup and are in the right holes.
different systems use different pins and plugs. the battery may have the same plug but the wires might be backwards?
OK
dumasman1,
How are you testing the receiver without a servo? Not that you have to use a servo, I just don't want to guess how you are doing the testing. The next question is are you sure the transmitter is operating on the same channel as the receiver, has power, etc?
- 'Doc
- 'Doc
